New Low-Beam Bulb
Old Feb 23, 2013 | 06:57 PM
PNY's Avatar
PNY
Default New Low-Beam Bulb
So i had a passenger low-beam bulb burn out at the end of this week. After some forum research it sounded like Philips was the safe bet. Found some stock equivalents on Amazon for $45 instead of $215 at the dealership. The original bulb I took out (for sure a bulb issue as it has a burn on the side of the glass) and the new bulb I replaced with have the same model number of 42402. However the new bulb is less "blue" than my driver side original bulb. Anyone have any insight? I'm totally bummed as I like the blue look more and I thought these would end up being identical.
Old Feb 23, 2013 | 07:04 PM
malujerry's Avatar
malujerry
i'm sure most of those bulbs are knock offs
try lsalazar@carsontoyota.com, OEM for $140 each, or TOMS 5500k, same price.
Old Feb 23, 2013 | 07:09 PM
edgeucated's Avatar
edgeucated
Whenever replacing bulbs, you should always replace bulbs as a pair. Its very hard to match color output perfectly and even more difficult when one bulb is older than the other. Also, if one bulb went out, there's a very good chance that the other bulb will go out soon too.
Not to burst your bubble, but the $45 bulb has to be a knockoff. Philips bulbs are very expensive, you will never find one for under $100.
Old Feb 23, 2013 | 07:15 PM
PNY's Avatar
PNY
I hope that's not the case. I ordered them from Xenon Corp on Amazon.
Old Feb 24, 2013 | 01:06 AM
aWorkOfArt's Avatar
aWorkOfArt
They are knock offs and are phillips style. I ordered some for my STi and works out just fine IMO
Old Feb 24, 2013 | 07:29 AM
PNY's Avatar
PNY
Okay, we'll just have to see how long she lasts Outside of OEM or TOMS does anyone else have a suggestion for a good replacement? I do like the color in the more "blue" range.
Old Feb 24, 2013 | 08:25 AM
Pqbrown's Avatar
Pqbrown
Check out morimoto bulbs, www.theretrofitsource.com
Old Feb 24, 2013 | 11:54 AM
DCoolBeans's Avatar
DCoolBeans
Its a knock of and as stated replace both when doing so. Every manufacture will always have a different tint to it
Old Feb 24, 2013 | 12:11 PM
fasttexasz's Avatar
fasttexasz
You have any problems with figment?
Old Feb 24, 2013 | 01:05 PM
DCoolBeans's Avatar
DCoolBeans
my figment is awesome!
Old Feb 25, 2013 | 08:45 AM
streetx's Avatar
streetx
HIDs should be replaced in pairs and you have knock offs
as the bulbs get more use on them they lose lumens and their color changes a little bit
Old Feb 25, 2013 | 08:59 AM
Pqbrown's Avatar
Pqbrown
I've had nothing but good experiences with TRS's products.
Old Feb 25, 2013 | 09:00 AM
Joe Z's Avatar
Joe Z
I have 3 different sets of OEM bulbs....
They ALL give off different colors..
My best pair is from my old 2008 ISF headlights.. Which I have installed into my 2011 IS headlights since they have the best color..
~ Joe Z
Old Feb 25, 2013 | 01:26 PM
PhiDeltBee's Avatar
PhiDeltBee
Believe it or not, I've bought 2 sets from vleds for dirt cheap and they look great. So cheap, if they go out, I'll just buy more. I started with 8k then switched to 5k. These are the ones I'm currently using for $30 a PAIR!
http://www.vleds.com/v-hids-xenon-he...00k-white.html
Great match to the factory led strips and match my 5k hid fogs.
For only $30 bucks, I gave it a shot and I REALLY like them.
Old Feb 25, 2013 | 04:27 PM
fasttexasz's Avatar
fasttexasz
Hate typos, oops! Got the bulbs in no problem, guess I just had them misaligned before.
ThermonMer
Nov 12, 2011 01:29 PM
ArmyofOne
Lighting
Mar 23, 2005 08:49 PM
