ISF problems & ML
Old Jan 7, 2013 | 11:05 PM
toky916's Avatar
toky916
Exclamation ISF problems & ML
Hello guys I'm new and only had my isf half a year bought it brand new 8 miles ..
I've been having issues with my F first was my breakes where just horrible everything come to a stop would sound ear pearcing . Took it back they replaced the pads. Then my headlights bubbled took it got them changed...Next day both headlight filled with water, took it back and replaced again both again next again water in left light this happend 3 Times !!!!
Today sad news leaving to work my sound system took a dump!!!! Compleatly sounds like ****** 😡
I mean this is a new car with alot of problems and sound system ML going out in half a year I don't go past 40-45 volume
Has a any one had problem with ML 2012 or what else have u had problems with ?
Also this is lexus supposed to be reliable and pursuit of perfection. I switched over from BMW of hopes of not having those problems !
I'm just one unhappy person atm
Old Jan 7, 2013 | 11:08 PM
ISF4life's Avatar
ISF4life
Tough lucks , bring back to dealer to fix it
Old Jan 7, 2013 | 11:19 PM
toky916's Avatar
toky916
Yea worst of luck My bmw seemed better . I love the F just problems up the ***
Old Jan 7, 2013 | 11:56 PM
Defratos's Avatar
Defratos
Sucks that you're having so many problems.
I've only recently bought my car with maybe 3 weeks ownership so far.
The only issue I've had so far is the damn driver side door keep making a noise which is going to drive me insane. I'm waiting until I hit 4,000km to take it to the dealers to sort it out.
Other than that my breaks are fine, no noise what so ever.
As for the ML sound system, well the only complaint I have about it is that it's Weak, I'm usually listening to music in the range or 55-60 and half the time that is still not load enough.
Hope you sort your problems out, a Lexus is known for reliability, but everyone makes mistakes from time to time.
Get the dealers to sort everything out or get you a replacement
Old Jan 8, 2013 | 12:00 AM
toky916's Avatar
toky916
I had both doors make noise , they resealed the doors now fine
Old Jan 8, 2013 | 12:03 AM
czhou14's Avatar
czhou14
i have a 2012 as well. no problems at all. the brakes squeak a tad bit coming to a stop. as far the as the sound system you cant blame lexus but ML. their system is great depending on what source you are using for music. my iphone was nice and loud. my LG optimus is horrible. i turned it to max and its not even close to my iphone.
Old Jan 8, 2013 | 12:05 AM
toky916's Avatar
toky916
I use iPhone with spotify 320kbps used to sound amazing try it
Old Jan 8, 2013 | 02:35 AM
kauaian's Avatar
kauaian
Wow seems you got a problematic car! It's the curse...it follows you...
Old Jan 8, 2013 | 03:36 AM
Boma's Avatar
Boma
CL Folding 25,000
As long as your car is still covered continue to bring it in and have everything documented. It is pretty unusual for a newer car like yours to have so many issues. On the bright side, aside from the brakes which is a known issue that is covered by a service bulletin, you haven't experienced mechanical issues yet. I mean it's not like your engine burst into flames and left you on the side of the road. All the issues you have are fixable and it is a good thing you're experiencing them early in your ownership.
And you're right about the pursuit of perfection, Lexus readily fixing up the issues you have is pursuing perfection!
Old Jan 8, 2013 | 04:18 PM
toky916's Avatar
toky916
Well a little news so before I took it to the dealer today, I Hooked up my iPad and worked like a charm turns out my IPhone 5 took a turn for the worst . Haha oh well as long as its not the car
Old Jan 8, 2013 | 04:54 PM
Fivepoint0's Avatar
Fivepoint0
Good to hear that the ML system is ok.
Old Jan 8, 2013 | 06:36 PM
hahahaf's Avatar
hahahaf
not one issue for me
Old Jan 8, 2013 | 06:42 PM
Kevin.IS's Avatar
Kevin.IS
Wow surprising to hear. You're still under warranty so everything should be fixed up and fine.
Old Jan 8, 2013 | 09:51 PM
toky916's Avatar
toky916
Yea Relieved that its fine got new IPhone 5 sounds better than my old 5 ... Odd phone's be having issues
kisf
Feb 8, 2025 09:38 AM
anandsay
IS F (2008-2014)
Jun 9, 2015 05:41 PM
jadeboy
IS F (2008-2014)
Aug 24, 2014 07:31 PM
FPILOT
IS F (2008-2014)
26
May 10, 2011 10:11 PM
