Need help with alignment
Old Nov 7, 2012 | 01:54 PM
TheHighLow's Avatar
TheHighLow
Default Need help with alignment
So after being lowered on KW V3s and getting wider tires (235-F/275-R) I noticed a considerable increase in tramlining, especially at WOT while switching lanes.
i'm guessing that the tires might something to do with it, however, I also want to make sure that my alignment is not the culprit either.
What are your thoughts?
I'm particularly interested in the toe.
Old Nov 7, 2012 | 05:37 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Tramlining is pure tires. Some are worse than others, some are a LOT better than others.
Old Nov 7, 2012 | 08:20 PM
TheHighLow's Avatar
TheHighLow
that's my hunch....i just wanted to rule out any obvious serious alignment issues. Car has 2k miles so it also shouldn't be suspension component related. I don't hear any clunking....steering wheel feels tight
Any idea if this can occur if there is a very slight mismatch in the bump settings in the front 2 shocks on the KW's?
Old Nov 7, 2012 | 08:41 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
No, tramlining is a byproduct of the pattern cut in the tread. The more linear patterns tend to tramline where the patterns with lots of cross elements tend not to.
dserban
Jan 18, 2015 04:20 AM
charly
HS 250h Model (2010-2012)
Jan 17, 2014 09:02 AM
horent135
Wheels, Tires & Brakes Forum
Dec 26, 2009 09:51 AM
GS4Will
Oct 31, 2001 01:40 PM
