oil level low
Same thing happened to me, the "Oil Level Low light" flashed on, and then went off... then after letting the car sit for a few hours I checked the oil and the level was fine. Not sure why my light went on...
If it makes you feel any better, the only problem with the is-f on inclines is the oil light
On my bmw the parking brake is so messed up I gotta put blocks behind my car for it to not roll into the street.....
I believe by law you only need to keep a journal of service and or keep invoices of the oil and filter purchases which can be considered acceptable in court of proof of your service diligence. This will then boil down to a workmanship issue and if you installed the parts correctly.
...but it is much less painless to go the "Do It For Me" route.
Some of the posts in here are hilarious to say the least!!!
I change my own oil..
There are MANY reasons why, but I am not going to even mention them here..
If the "Oil Level Low light" is coming on often, that you don't have enough oil in the system.
If it's once in a blue moon, when you’re parked on an incline, it could very well be that the oil sensor is not detecting enough oil at that time..
(Which is not a bad thing, but it could also be that you dont have the right amount in there.)
Officially, the IS-F calls for 9.8 Qts of oil w/ Filter..
That translates to approx. 9 Qts & 26 Ozs.
Now, I have taken the stance to put all 10 Qts in, basically because I allow my oil to drip for an extended amount of time.. So I am sure I am getting a little extra out..
The extra .2 Qts of oil I put in equates to approx. 6 Ozs..
Check your dipsticks once a month between oil changes.
I know I do..
~ Joe Z
I know I do..
~ Joe Z
Thankfully the Bimmers do it all in a computer so it'll tell me when I need +1qt or +2qt
The average person who changes their own oil is looking to save money plain and simple. Chances are most of those who change their own oil, let alone those who take it to a dealer will pay extra money for a UOA. Most people don't care about how much silicon and boron was left in the oil. Not everyone is a master tech that has the liberty to play with old oil for kicks.
I work in the car business I hear complaints all the time about simple oil changes gone wrong. I'd rather not be a statistic.
ABbirds
Jun 11, 2018 09:08 PM
