transmission
I asked the dealer at one time if there were any TCU updates and was told at that time there were not.
This obviously seems to be more than a one-off issue. What I'd like to know is whether this is
a) normal behavior that is triggered by a rare combination of factors (cold, pedal position, speed, etc).
b) software glitch (trans cal bug that they didn't catch in development)
c) hardware problem (sticky valve, as some have speculated above)
I doubt a) is right, at least I have a hard time believing the development engineers coded this behavior on purpose because it results in very poor driveability. That leads to b) or c) and I'm leaning towards b).
Unfortunately this is one of those behaviors that is impossible to replicate on demand, but if it's happening to a large proportion of posters here there's a good chance Lexus is aware of it. If enough owners complain it could filter up and back down as a service bulletin. I'll definitely mention it the next time my car goes in.
1. You accelerate hard.
2. It's in D.
3. The car does not upshift for a few seconds and stays in gear.
4. Sport mode (?) (I'm usually in sport mode so not sure if it happens in normal mode)
I'm sorry but this is actually NOT a problem, but a software feature. Like some have mentioned, the shift software has a predictive nature to it, so it will delay upshifts if it senses aggressive driving, just like it will shift at higher points if you have a lead foot. I was actually very impressed when it happened to me the first few times, because I was on the freeway and trying to maneuver across multiple lanes during a merge. So the car stayed in a lower gear and allowed me to stay in the optimal power band even in D, until I got to where I want to go, then it upshifted. If you keep the gas down, it will upshift when it nears redline. How the car behaves depends on your throttle control during this time.
Yes, like all software there are edge cases where it predicts incorrectly. There was a couple of times when I actually didn't need it to stay in gear that long, but it was still useful regardless. Nothing wrong with being in the power band when you're trying to get somewhere quick!
</Thead>
2. It's in D.
</Thead>
Throttle position at 1/2 (or less) and lifting to idle seems to be a pretty clear condition for an upshift - but it doesn't. I've basically had the throttle feathered with the momentum of the car keeping the revs above 4k, and it still won't shift for a good 5 seconds.
p.s. I had to laugh when you say it sounds like people haven't driven an automatic performance car before... IMO there wasn't one on the road before the ISF
I think that it has something to do with the manual/automatic gate on the shifter because if you shift it over to manual and then back to automatic it seems to go ahead and shift normally.
Pat
2. It's in D.
</Thead>
This is NOT a feature of a high performance transmission. I am well aware of the transmission holding gears in sport mode, this is not that. This is occurring at moderate throttle positions in normal mode, only in 2nd gear and only when cold. It is not predictable and not reproduceable.
Never driven an automatic performance car? Does a Porsche 996 twin turbo tiptronic count?
2. It's in D.
Only in Sport mode, and temperature seems to have no impact on it.
Thread here:
http://www.lexusfforum.com/forums/showthread.php?t=1177
Also, the solution is to flick the shifter into manual. You can then upshift or just flick it back to automatic.
