nav sound icons?
Old Sep 4, 2009 | 03:59 PM
PHXF's Avatar
PHXF
Question nav sound icons?
Hey guys,
I'm trying to set the local speed cams in my NAV to chime when I approach a speedcam. I've got the locations marked in my memory points, and I'm going into the Icon menu to change the map icon to a "with sound" icon, but I'm not getting any sound when I approach the locations.
The "with sound" icons have a speaker icon next to them which is there presumably so you can hear the sound before selecting it. When I press those buttons, I'm not getting any sound either.
Any ideas? Does yours do this too? I'm thinking there is some secret to it, like having your mirror control set to L or R in order for the mirrors to tilt in reverse.
Old Sep 27, 2009 | 11:50 PM
IS3CM's Avatar
IS3CM
Make sure your guidance volume is up under the menu section. If that's not it reset your nav settings to default and try again. If that doesn't work then ask the dealership when you go for service.
Old Sep 28, 2009 | 04:53 AM
jctheplaya's Avatar
jctheplaya
Yeah, i heard the preview of the sounds before def check your volume! Again if it doesn't work doing what IS3CM said. Reset or go to the dealer
DougT59
Apr 15, 2019 11:11 AM
Helterran
Apr 28, 2014 03:32 AM
mcitron
HS 250h Model (2010-2012)
Jun 16, 2012 07:05 PM
PHXF
Sep 9, 2009 10:20 PM
Shinchan
Oct 11, 2006 08:00 AM
