transmission
Im testing out the Blitz Throttle Control unit right now...
____________
_____________
Regards,
Joe Z
____________
_____________
ECO Mode - is used primarily to increase bottom end response. Accelerate point moves to lower end make a car moving earlier than factory stock setting, this reduces the driver having to continually press on the throttle which result to help fuel economy consumption. Regular street driving more likely suit with "ECO" mode.
*** "ECO" is a stance of ECONOMY that the mode saves most fuel consumption compared among in BLITZ Throttle Controller pre-programmed modes. ***
SP1 Mode - throttle is opened greater at lower revs or higher revs and one range higher on mid revs compared to factory settings. This mode consider as Sport Mode with in a balance of comfort of drivability.
SP2 Mode - approximately twice-higher range at lower revs and mid revs compared to SP1 Mode designed for sport driving and circuit use. Significant response improvement which never achieved by mechanical throttle valve (Cable Type).
SP3 Mode - is the most aggressive setting for sports driving, at 50% acceleration, throttle at full engagement at 100%. Most acceleration improvement you could feel among the 4 modes.
Regards,
Joe Z
Joe, interested in hearing your feedback. It seems like this just amps up the throttle position sensor input which is good to a point though I'm interested as to whether it takes away any of the "feel". Just like with brakes on/off isn't always good.
BTW: Do you have it on the car now and are evaluating or is to be on the car soon?
I just got the Blitz unit but haven't installed it yet.....does anyone know if I also need some type of reverse relay with this unit...I remeber reading a post a while back about something like that but can't seem to find it anywhere? Joe Z maybe you know about this
At WOT in stock trim, the throttle flap is never fully opened..
I believe with this unit the throttle flap opens to 100% on SP3 when @ WOT...
I will have a thread up soon and maybe some track runs this weekend..
Joe Z
Blitz's Reverse Cancel Harness (must be purchased separately).
This safety harness automatically sets the Throttle Controller to your vehicle's stock throttle map when reverse is engaged and then resumes your specified map once you are back into a forward gear. We STRONGLY RECOMMEND using the Reverse Cancel Harness for all street driven vehicles. **
Also, I thought that this controller only affects the throttle response, so it can't replace sport mode, because sport mode also changes the electronic steering as well as the shift mapping...?
I did a quick drive on a F on SP3 and it was insane for street use cuz it's hard to drive smoothly. It'd be perfect for track use though.
Wait... this implies that the car is not able to use all of its power unless the throttle is re-mapped using this controller. Am I misreading this? That doesn't seem right...
In stock trim, the throttle flap never opens at 100%
2) I never said it replaces Sport Mode.. it just enhanes the throttle response on the gas pedal .. and it does it also when in Sport Mode is switched ON
3) I agree.. SP3 and Sport Mode make Steet Driving Very Fun!!
Joe Z
joez
So from what you are saying (that the TBody does not open 100% in stock trim) it would be intersting to see if this product would actually make more power... even if its 1 or 2 HP. what do you think?
I have the blitz control and no you dont need a reverse relay or something it's simply plug and play very easy installation,just get the one for the f wich on the is 350 is the same.i am very happy with it, does change something on the car,the feeling is totaly different.
