replacing pads
Old Mar 11, 2009 | 11:34 PM
lx470man's Avatar
lx470man
Default replacing pads
how hard is it to replace the brake pads on the brembo's?
is it simple as taking out the pins andtaking the old ones out and putting the new ones in?
Old Mar 12, 2009 | 04:19 AM
caymandive's Avatar
caymandive
11 Second Club
What pads are you replacing with? As for the procedure it's just as you said. Easy as pulling pins. I'm going to need to replace mine very very soon and plan on going with the Ferodo DS2500 pads which can be had for $220 for the front set.
Old Mar 12, 2009 | 07:42 AM
Reciprocal's Avatar
Reciprocal
Are you sure it's that easy for the rears? On other cars the fronts were usually easy but in back a hassle because of the parking brake.
Old Mar 12, 2009 | 10:07 AM
lx470man's Avatar
lx470man
is there a diy for this?
Old Mar 12, 2009 | 10:36 AM
caymandive's Avatar
caymandive
11 Second Club
Here is a DIY thread for the front brakes of an IS350. The procedure is/should be nearly the same for the IS-F.
https://www.clublexus.com/forums/sus...g-caliper.html
Old Mar 12, 2009 | 04:48 PM
kyang91's Avatar
kyang91
It should be a very easy switch, I just did my Rotora BBK the other day and it was easy as pie.
Old Mar 12, 2009 | 05:38 PM
lx470man's Avatar
lx470man
so the rears are the same procedure?
Old Mar 12, 2009 | 06:26 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
I wouldn't exactly say that. Hammer out the top pin with a 5mm pin punch, remove the anti-rattle spring, hammer out the lower pin, then remove the bolt and pad guide tie rod to get the pads out. Installation starts with the lower pin first, then the bolt and pad guide tie rod, then anti-rattle spring, then upper pin. Other than that, yeah, it's about the same for fronts and rears.
Yamaheart
CT 200h Model (2011-2017)
Jan 10, 2020 03:46 PM
ommar420
Suspension and Brakes
Jan 30, 2011 07:54 PM
lexus-is2
Jan 30, 2010 06:06 AM
Skyhigh82
RX - 1st Gen (1999-2003)
14
Jul 23, 2009 10:38 AM
songkp012
Jan 23, 2009 11:03 PM
