Official IS-F Drag Time/Dyno Time/Performance Thread
Old Oct 8, 2012 | 11:41 AM
  #271
zapa's Avatar
zapa
Originally Posted by caymandive
^the graph shows "STD" which is uncorrected. Should show "SAE" which would indicate correction applied. Btw where did you dyno?
ahh it does and ill see If i have the corrected versions. temp was 83.12, 29.81 in-hg and humidity was 39%, STD: 1.02.
Im not a dyno expert so let me know what that means
i dynoed at Ramey Built also
Old Oct 8, 2012 | 06:52 PM
  #272
zapa's Avatar
zapa
can anyone tell me what the corrected number would be??
Old Oct 9, 2012 | 06:47 AM
  #273
madastep's Avatar
madastep
SAE Smoothing 5 i believe
Old Oct 9, 2012 | 08:48 AM
  #274
BS ISF's Avatar
BS ISF
toothdoc, where did you run this weekend? was supposed to head to route 66 and of course they cancelled due to it being too cold! such BS! that place sucks.
Old Oct 9, 2012 | 11:20 PM
  #275
ToothDoc's Avatar
ToothDoc
11 Second Club
Great Lakes dragaway in Wisconsin. I live in the north suburbs so GLD is only 40 minutes from me. They seem to always have good track prep and they're usually open until November.
Old Oct 10, 2012 | 11:43 AM
  #276
BS ISF's Avatar
BS ISF
so did you run after KOTS? a couple buds and i were gonna head up there but thought you could only run after KOTS was done.
Old Oct 13, 2012 | 02:32 PM
  #277
Gearbangin's Avatar
Gearbangin
First pass stock rig 12.9@110.7. Lol last time same track 22 lbs boost my turbo lex ran 12.00@124.
Old Oct 13, 2012 | 06:37 PM
  #278
2ltrgsr's Avatar
2ltrgsr
When you were at ramey built, did you see a red right hand drive turbo integra?
Old Oct 13, 2012 | 08:28 PM
  #279
zapa's Avatar
zapa
Yess i did actually. Is it yours??
Old Oct 22, 2012 | 01:54 PM
  #280
BS ISF's Avatar
BS ISF
well not what i expected with the DA in the 400's but what can ya do. 12.90 @ 110 on sunday at byron raceway in illinois. I'm intake, borla catback and et street on is350 rims. track had over 400+ cars so only got 2 passes in in 5 hours! was terrible. need to really get used to getting out of the hole cause my 60' times were 2.06 on both runs. hope to get back out this week!
Old Oct 22, 2012 | 10:26 PM
  #281
ToothDoc's Avatar
ToothDoc
11 Second Club
400s DA isn't really that bad actually.. could be all that waiting and cold engine? I'm going to GLD this weekend to see if I can break into the 11s. From the weather forecast, looks like it'll be cold enough - but cloudy is usually lower pressures. We'll see...
Old Oct 25, 2012 | 09:12 AM
  #282
oufan2929's Avatar
oufan2929
I assume he meant that with that low of a DA that he would run better times. That's a DA we NEVER get around here in OK. Best we get is about 1,000ft.
Old Oct 28, 2012 | 08:11 PM
  #283
ToothDoc's Avatar
ToothDoc
11 Second Club
What's up folks? I ran on Friday and I ran Today. Did some experimentation. Friday was 48 and today was 46 degrees and the pressure on both days was 30.2 and 30.3 inches. Both days the dew point was like 30 degrees so very similar conditions. Today was at least a 5-10 mph higher headwind for sure and as a result, I was trapping 1 mph slower despite the equivalent 1/8 mph and 60' times. I think overall, the actual headwind was 15-20 mph!!!
But here are my best time slips. I did break 12.0 finally - must've caught a break in the wind or something. I am car 828 and 641.
Attached Thumbnails Official IS-F Drag Time/Dyno Time/Performance Thread-20121028_215233.jpg
Old Oct 28, 2012 | 08:17 PM
  #284
ToothDoc's Avatar
ToothDoc
11 Second Club
I didn't break the all-motor record, but I do believe I broke the all-motor 60' LOL. 1.827 felt pretty darn good! My best trap was 116.92 and my best ET was 11.998 Best 1/8 speed was 93.28 mph@7.799
I did a little reading on DA and from it appears, the actual temperature seems to have the greatest impact on DA. I think if I run at 38 degrees or colder, I think I might be able to cut a 11.90. Here's to hoping the drag season goes for a couple of more weeks so I get another shot at it. I'm also going to put on coilovers to get the weight down even more. I'm not ditching the seats yet nor removing mufflers quite yet. LOL
One last thing - I did the DA calculation and based on dragtimes' website, the other day and today came out to e -272 and -308 feet below sea level.
Old Oct 29, 2012 | 02:53 AM
  #285
Gymkata's Avatar
Gymkata
Congratulations ToothDoc...way to keep working toward your goal.
