IS-F top speed?
If the IS 350 is aerodynamically limited to 167 mph, then the F should be limited to 167 mph. Unless the shark gills behind the front wheels are functional. I'm kind of with ride450, 155 mph is the accepted Autobahn electronic speedlimiter setting.
It better be 167, ocean pkwy here on Long Island suggests 55MPH... pssshhhh
If the IS350 is drag limited to 167.... then the 100 extra hp in the IS-F will increase its it beyond 167
Sorry to bring back a dead thread, but what is the theoretical top speed of the IS-F if the limiter was removed. It can hit the limited top speed of 170 in 6th at 6450rpm, what can it get in 8th with an overall gear ratio of 2.01:1
170 in 8th is at 4400 rpm, leaving 2200 rpm if the limiter were removed.
Do you think it'll have enough torque to push much faster? 180?
I've heard from reviews that the top speed is 168 mph. I know for a fact it is not limited at 155, via electronics or aerodynamically. I have got to 140 fairly easily and can say from experience, it has way more engine left.
The ISF is electronically limited to 172 mph. If you remove the limiter the car can reach a drag limited top speed of 186 mph, it was mentioned in an interview with the ISF designer.
