IS C Discussion about the convertible IS C model
2015 IS250C - PCS disable
Old Oct 7, 2019 | 10:23 AM
PaulyGS300's Avatar
PaulyGS300
Default 2015 IS250C - PCS disable
Does anyone know if there is a way to fully disable the PCS on the 2015 IS conv.? My car sustained front end damage and the new sensor is over $2000 plus install and calibration $700+ at the dealer. I am not looking to replace this part but the PCS light is on the dash and the "Check PCS system" error message keeps flashing. I would love to just disable this option on the car and not worry about replacing it. Any help is greatly appreciated.
Thanks
Old Oct 7, 2019 | 01:30 PM
lockedlex's Avatar
lockedlex
You can disable PCS using the car configuration menu buttons to the right of the convertible switch (looks like a rocker with a on/off button in the middle). HOWEVER, that might only disable the actual response system, but not workaround the system check that's probably done when the car starts up--and then gives you a possible error.
Why not fix it properly through an insurance claim? Also, ironically, PCS should have warned you of a possible collision to avoid it.
Also, FWIW, PCS is very rare on any IS, it's certainly something I've enjoyed and want to ensure is working properly.
Old Oct 8, 2019 | 06:28 AM
PaulyGS300's Avatar
PaulyGS300
Right, the button next to the TOP control only turns the PCS ON or OFF. I have read in several posts that the PCS actually had caused or would have caused many drivers to get rear ended. Especially when driving dynamically. I really don't use the feature and therefore would rather avoid the additional cost. Thank you for the feedback.
Old Oct 8, 2019 | 06:55 AM
PaulyGS300's Avatar
PaulyGS300
I love my lexus cars and they have served me well. But some of the components are getting ridiculously expensive. Over $2000 for a small eletronic box that probably cost under $100 in to make. Not justifiable.
LLK
Oct 8, 2019 06:57 AM
ezdraft
Jul 18, 2018 05:25 AM
Is200tnc
Jul 19, 2017 06:40 PM
nosml
Dec 20, 2001 07:22 AM
