IS C Discussion about the convertible IS C model
Water in trunk IS250C
Old Oct 7, 2018 | 09:35 AM
Peterke's Avatar
Peterke
Angry Water in trunk IS250C
Hi all,
I've got a 2011 Lexus IS250C, which I started parking outside since last year (had to make room for the Jaguar F-Pace I got). The car is parked on an incline (there are hills everywhere in San Francisco). I noticed last winter that a lot of water came into the trunk and pooled at the spare tire. I had the dealer replace some seals, but this weekend I noticed again water in the trunk. It has not rained at all in the last 2 weeks, but humidity has increased so every morning there was condensation on the car. Does anybody know where these leaks could be coming from and how these can get fixed. I don't want to spend another $1,200 at the dealer for no results in getting the leaks fixed.
Thanks
Old Oct 8, 2018 | 04:31 PM
twleblanc's Avatar
twleblanc
Are you parking with the nose downhill or uphill?
I’ve found water ingress if I’m parked in a nose down position, but not when flat or nose up.
Old Oct 15, 2018 | 09:30 AM
Peterke's Avatar
Peterke
I'm parked nose uphill. I was hoping turning it around would fix it. I'm gonna try this.
Old Dec 28, 2018 | 05:12 PM
CTimmons's Avatar
CTimmons
Default Same Issue
Going to try parking nose down in my incline driveway.
Ive been parking nose down.
Q: are you leaking on both sides? I'm only on the driver side.
Thanks
Old Jan 1, 2019 | 10:48 PM
Peterke's Avatar
Peterke
I have the car parked nose uphill (about 15-20 degrees). I don't know which side the water comes in mostly. The dealer had tested it with the nose downhill and did not see any water ingress.
They just now tested nose uphill and found some leaking seals they're replacing. We'll see how much this comes out to cost me. Hopefully this fixes the issue or I'm selling the car.
Cheers
Old Feb 19, 2019 | 01:51 AM
lockedlex's Avatar
lockedlex
Hi, Any progress on this Peterke?
Old Jun 1, 2021 | 07:25 AM
kingofbyte's Avatar
kingofbyte
Looking for some feedback here - just bought a used 2010 IS 350C and noticed this problem of water in the trunk. I just checked the 'side drains' and they're working fine. I was parked in my driveway that has a very slight incline with the nose up. Has anyone solved this?
Old Jun 8, 2021 | 01:26 AM
ed21x's Avatar
ed21x
I actually had this issue repaired by the dealership within warranty. Will try to look up the description, but I did remember they had to change a seal/lining somewhere.
Old Jun 9, 2021 | 06:17 AM
drewduq's Avatar
drewduq
2nd gear
New to the ISC family this year, so limited experience.
Are you talking about water draining into the trunk in general, or when putting the top down after washing/rain? I've noticed that the channels hold water (especially on incline with nose up) that dumps into the trunk compartment when the top operates. This is greatly reduced to almost nothing if I wash the car on the same inline (maybe 15-20%) with the nose down.
Also to note: drains are clear. I've made the assumption this is a design that didn't factor the vehicle being parked on an incline for proper drainage.
Thoughts and observations?
Old Jul 21, 2021 | 09:23 AM
user 3697812901's Avatar
user 3697812901
9th Gear
Default Isc 2010
My 350 gets some when washing on incline. I gorilla glued the seal on areas of trunk that seemed to be poor adherence. Its improved but i just put a towel in trunk when i wash it.
dewana421
Jun 27, 2023 05:37 AM
Lac
20
Oct 22, 2020 04:36 PM
topgun129
Jan 24, 2010 07:38 PM
klvaleri
GS - 1st Gen (1993-1997)
Oct 28, 2009 09:23 AM
Jmai22
31
Sep 25, 2004 08:03 PM
