IS C Discussion about the convertible IS C model
Lexus IS Convertible 250/350c Top Malfunction/Not Working FIX
Old Dec 15, 2023 | 03:44 PM
imkIS350c's Avatar
imkIS350c
Post Lexus IS Convertible 250/350c Top Malfunction/Not Working FIX
Greetings everyone,
I'd like to provide a solution for a prevalent issue related to top malfunction, specifically caused by a loose internal component in the SWITCH. I've prepared some videos to guide you through both temporary/quick and permanent fixes.
I trust these will be helpful.
Old Dec 15, 2023 | 05:54 PM
RonK's Avatar
RonK
Veteran: Marine Corps
Thank you for the simple directions. What is a silicone pad? Can you use anything else?
Old Dec 15, 2023 | 06:24 PM
imkIS350c's Avatar
imkIS350c
You are very welcome. You can use anything. I used a silicone anti-slip pad.
Old Dec 17, 2023 | 03:26 AM
Mike246's Avatar
Mike246
What strikes me (and doubtless others) is that Lexus could design this brilliant retractable top and yet a point of failure is at the mechanical operating switch.
I have not experienced this fault but if I do, your video will prove most helpful.
Mike
Old Dec 17, 2023 | 08:04 AM
imkIS350c's Avatar
imkIS350c
Mike
I agree. If you don’t want to spend time to disassemble, you can just replace the switch (it is around 100$).
Old Jan 25, 2024 | 05:14 PM
larrychery's Avatar
larrychery
I replaced my switch with an OEM new one and still occasionally have the open/shut stop mid sequence. I think it's the fault of the manufacturing of the switch itself. I'll give this a try, thanks for posting.
Old Jan 25, 2024 | 05:19 PM
imkIS350c's Avatar
imkIS350c
I never had any problem after I fixed the switch. I hope the video helps you.
Old Jan 25, 2024 | 08:45 PM
larrychery's Avatar
larrychery
I have just one slight criticism for your videos, if you don't mind me telling you?
Old Jan 26, 2024 | 03:42 AM
imkIS350c's Avatar
imkIS350c
i guess some people don’t want to be known. I feel happy if I can help even one person.
jonas's RX
IS C
Feb 15, 2020 06:32 PM
socaldrvr
Jan 6, 2019 12:57 PM
melstepp
IS C
Aug 5, 2017 09:40 AM
Jaydemm
May 5, 2014 12:53 PM
