Transmission Fluid Drain and Change without dropping filter/ Pan
Old Apr 30, 2025 | 07:03 AM
18borat's Avatar
18borat
Default Transmission Fluid Drain and Change without dropping filter/ Pan
Wondering if anyone here knows if the ATF can be simply drained and refilled again without dropping the filter/ pan? Also how much ATV does the IS500 take?
If someone can direct me towards a good guide on ATF oil change that would be amazing. Worst case, I will try to get the info from TIS.
Also thinking of switching to Valvoline Maxlife as the reviews for Toyota ATF is not the best.
Old Apr 30, 2025 | 07:47 AM
G30540i's Avatar
G30540i
Since we have the same 8 speed as the IS350, I would suspect the YouTube videos on it would apply towards ours too. There’s a drain and overfill bolts on the bottom of the pain and a fill bolt on the driver’s side of the transmission. You do need the car perfectly level and the transmission up to temp when doing the final fill of the transmission. I miss the time when transmissions had dipsticks and you could fill them from the top!
dewana421
Dec 31, 2024 03:21 PM
MrsWatts
13
Aug 4, 2020 12:32 PM
Stemmer
RX - 1st Gen (1999-2003)
19
Jun 5, 2016 04:05 AM
Kalogerus
Apr 9, 2012 12:49 AM
mac187
GS - 1st Gen (1993-1997)
Aug 26, 2008 12:10 PM
