Issue with both remotes
Old Oct 27, 2024 | 11:08 AM
DeepBlue99's Avatar
DeepBlue99
Default Issue with both remotes
I usually use the door handle mounted controls to lock and unlock the car, so this might have been the case for a while. Those still work. However, I noticed today that buttons on both remotes are not working. Batteries are less than 6 months old. But I was planning to switching them out to troubleshoot.
Is there some sort of button lockout failsafe feature that I may have activated? If that's not the case, and given that both remotes are having the same issue simultaneously... makes me think its the car.
Old Oct 27, 2024 | 12:30 PM
DeepBlue99's Avatar
DeepBlue99
Did a bit troubleshooting, new battery no change. Car is definitely receiving signals. Just seems like lock, unlock, trunk, panic functions are disabled. I can do press press hold lock button to start the car. Also, holding down lock and unlock buttons for like 5+ seconds cycles all doors unlock or just drivers door unlock.
Seems to be nothing in the manual about this.
Old Oct 27, 2024 | 12:55 PM
DeepBlue99's Avatar
DeepBlue99
Well, look at this...
https://www.clublexus.com/forums/is-...d-working.html
I guess I found my problem. Yes, I was recently in the door features customization screen. I believe I made one or two adjustments. I had my fob with me and another fob from wife's NX closeby. Pretty outrageous that this is still a problem across several lines. Now I have to haul *** to the dealership as this can't be put off till next service. That will be at least 4-5 months.
Old Oct 27, 2024 | 01:26 PM
Benibiker1558's Avatar
Benibiker1558
The only good thing is it’s a quick fix, like 15-20 minutes once they get to it. I don’t think Lexus has put it together that having two different key fobs with you while customizing settings will cause a huge issue.
Old Oct 27, 2024 | 01:33 PM
DeepBlue99's Avatar
DeepBlue99
This sort of hilarity is not something I would expect from Toyota/Lexus. If this was a Ford, I would just shrug and go about my business. Funny thing is that I was just over there yesterday picking up a little clip I broke the other day.
Maybe I'll see if they want to make a house call...
Old Oct 29, 2024 | 07:19 AM
DeepBlue99's Avatar
DeepBlue99
Issue resolved this morning. Writeup says its a known issue. Everything seems to be back including the door lock/unlock beep.
I did notice something peculiar when I got home that I was hoping one of you guys can double check for me. If I leave a fob in the car and try to lock it via door controls, I get an error beep, no lock. If I leave one of the fobs in the car and lock it with the second fob, it does lock. I don't believe that should be the case. Seems counter intuitive.
Old Oct 29, 2024 | 08:50 AM
lsbrodsky's Avatar
lsbrodsky
Veteran: Navy
That is exactly the behavior of my new car.
Larry
Old Oct 29, 2024 | 09:16 AM
Benibiker1558
Mine is the same too. It really makes sense if you think about it. You have one fob with you, you accidently leave it in the car, you press the door control to lock, hopefully it won't let you lock yourself out. Now if you leave a fob inside but have another fob with you and you press the lock on the fob no problem, you have one outside the car so it'll lock.
Old Oct 29, 2024 | 04:58 PM
DeepBlue99's Avatar
DeepBlue99
Thank you both! Appreciate the sanity check. Maybe I was thinking of a different car.
Old Apr 25, 2025 | 12:31 PM
303cuIS's Avatar
303cuIS
7th Gear
Default Just ran into the remote issue...
Just had the issue when I turned off the beeps when locking/unlocking. Both fob buttons would not do anything. Lexus fixed it but no real, lasting "fix" was presented to me. Avoid those settings I guess. I will see if I can get some attention on this from Lexus but not sure they will care.
Old Apr 25, 2025 | 04:05 PM
Benibiker1558
Ever since I had my problem, I try not to customize anything in that menu for fear it'll happen again. Still, I think my problem was caused by having a set of keys to my Lexus NX on me while in the menu and that confused the system. Seems like a silly bug in the system.
Old Apr 25, 2025 | 04:41 PM
EngIceDave's Avatar
EngIceDave
*NOTE TO SELF*
Don’t mess with the car settings when wifey-poo is in the car.
ThE0nE
Sep 17, 2021 10:10 AM
clarky0
Oct 19, 2012 11:42 AM
rissaly604
IS - 1st Gen (2001-2005)
Apr 4, 2011 08:37 AM
keycard198
Dec 27, 2009 02:22 PM
uae
Aug 21, 2007 04:30 PM
