Apple car play connection issue?
Old Feb 18, 2024 | 05:25 PM
OCJACKAL's Avatar
OCJACKAL
Default Apple car play connection issue?
Whats up party people!?!?!
I got a question, any of you iPhone users experience connection issues? Ever since I got the new iPhone, the cable I was using only connects sometimes. Ive also tried different cables and I get the same result.. I haven't been able to figure out what I do differently when it does connect.. SO that is why I am posting this..
Also, when I plug in the phone to the cable it shows charging for a few seconds then not charging, then charging then not charging.. If any of you have any ideas I would be more than willing to try them out lol
Thanks in advance
Old Feb 18, 2024 | 08:43 PM
jororo's Avatar
jororo
I’ve noticed similar issues with cheap iPhone cables off Amazon, even the ones that claim to be “MFi certified.” And newer iPhones seem to be more sensitive to it.
Also have seen problems with multi prong cables as some of the prongs provide power only while other prongs can handle both power & data (ie can be used for CarPlay).
Only other thing is perhaps some lint/etc got into the input on the car or phone. That, and sure you know this, but worth making sure it’s plugged into the lower of the two USB-A inputs.
Old Feb 18, 2024 | 10:19 PM
Phresh2010's Avatar
Phresh2010
I've had this issue also when I switched to the iPhone 15 pro max. It was happening with any cable I used even with well reputable MFI certified brands like Anker and Belkin.
However, once I started using the bottom USB port, issue went away and haven't had any connection issues since.
Old Feb 19, 2024 | 05:22 AM
04gita's Avatar
04gita
Since you've already tried different cables, this advice is the next place to look to solve intermittent/finicky connection issues. I've found Carplay/AA to be the first place any kind physical connector issue will rear its head.
Old Feb 19, 2024 | 05:41 AM
DLPTony's Avatar
DLPTony
2nd what has been posted thus far.
I had to switch to the official Apple cable and it worked for a time. The phone sits in the passenger seat, but it seems to get a kink after a while and has to be replaced. Upgraded to a metallic/uber-flexible cable and it seems to do the trick.
1. Make sure the phone and Carplay apps are up to date.
2. Make sure you hear a solid ‘snap’ when the cable is inserted.
Old Feb 19, 2024 | 06:10 AM
Admonkey's Avatar
Admonkey
All of the above, and if it continues to fail, hard-restart your phone.
Old Feb 19, 2024 | 06:45 AM
kcarr91's Avatar
kcarr91
Same exact thing happened to me when switching to my iPhone 15 Pro. Thought the top port was broken and was going to bring it up next service. However seeing comments like this makes me think it is just something with the way that is wired from the factory.
Old Feb 19, 2024 | 12:15 PM
OCJACKAL's Avatar
OCJACKAL
Ok, so I checked which port I was using, and it was plugged into the top one... I switched to the bottom port and it worked.. only tried it once, but so far it looks like that solved my problem.. Thanks everyone
Old Feb 19, 2024 | 07:07 PM
arruda89's Avatar
arruda89
Learned this when I got my 15 pro. Use the bottom port only. I’m assuming it’s a faster port
redzepplun
RX - 3rd Gen (2010-2015)
Dec 28, 2023 10:17 AM
hbarchha
ES - 7th Gen (2019-2025)
34
Jun 28, 2023 01:30 PM
Newnxer
NX - 2nd Gen (2022-current)
Jun 3, 2023 05:14 AM
dotbowels
Oct 5, 2013 02:58 PM
saz25
17
Sep 17, 2012 12:50 PM
