How’s your AC?
Old Jun 25, 2022 | 03:57 PM
  #31
Carolina50's Avatar
Carolina50
Originally Posted by DLPTony
LOL @ Ball Vent!
And all that is needed is a GoBag!!!
Old Jun 25, 2022 | 04:01 PM
  #32
DLPTony's Avatar
DLPTony
BWAHAHAHA!!! Right! 🤘🏽
Old Jun 26, 2022 | 01:57 PM
  #33
Billyb0b's Avatar
Billyb0b
8th Gear
Originally Posted by macmaster
Exactly. You my friend, are not a money saver.
The AC system, when operating, does add a slight load to the engine, which could slightly increase gas usage. Though this usage would not be recognized by most consumers.
Running the air conditioner when driving is actually more efficient and saves gas as compared to driving with the windows down. When the windows are up, the vehicle is more aerodynamic. When the windows are down, this creates excess drag on the vehicle, which increases resistance.
Old Jun 26, 2022 | 03:17 PM
  #34
jororo's Avatar
jororo
Tested mine yesterday and today. AC vents stream in hotter air if AC is set to a higher temp before being turned off, but if I set it to LO then turn off the AC, the air that still flows thru the vents is about the same as the outdoor temperature.
This was all city driving after engine had warmed up, with outside temp of 62 and 90 … no idea what’s going on with those who have hot air being forced in no matter what temp they turn off the AC at.
Old Jun 27, 2022 | 11:40 PM
  #35
EhArgh's Avatar
EhArgh
I noticed this today as it hit close to 31 degrees celsius and it felt very weak comapred to my Model 3. The "ventilated" were barely working.
Old Jun 28, 2022 | 06:45 AM
  #36
95bat's Avatar
95bat
The AC was was weak or the ventilated seats? At 88F the AC should not be weak.
Old Jun 28, 2022 | 01:10 PM
  #37
Billyb0b's Avatar
Billyb0b
8th Gear
my AC is fine but the ventilated seats are absolutely horrible. This is my 5th IS and they all have been bad. With exception to the 2010 that I once owned. Those seats got ice cold. Even the back of seat.
Old Jun 28, 2022 | 05:29 PM
  #38
95bat's Avatar
95bat
Yeah, that's how my other Lexus vehicles have been. Cold back and butt. The IS is the weakest. I just figured they got better as you went higher up the model line up with the IS being the lowest.
Old Jun 28, 2022 | 05:39 PM
  #39
macmaster's Avatar
macmaster
^Like Mark Levinson lol
Old Jun 28, 2022 | 06:45 PM
  #40
95bat's Avatar
95bat
LOL yup! They all advertise mega watts, but they certainly do get better as you go up the line up.
Old Jun 28, 2022 | 11:35 PM
  #41
EhArgh's Avatar
EhArgh
Both were weak unfortunately, might get them checked at the next service.
Old Jun 29, 2022 | 11:46 AM
  #42
swaangin's Avatar
swaangin
Ran a small test last night, air temp & flow is different in all these settings:
A/C OFF:
Circulation: On
^ This setting had the warmest heat coming through
A/C OFF:
Circulation: Off
A/C OFF:
Circulation: Off
Sunroof opened / tilted open
^ The sunroof tilted option + circulation off provides highest air flow & lowest temperature from what I experienced
Old Jun 30, 2022 | 10:29 AM
  #43
DLPTony's Avatar
DLPTony
A quick recording of the fan speed on high, engine off.
File Type: mov
Old Jun 30, 2022 | 10:46 AM
  #44
arentz07's Avatar
arentz07
I'm so lost on this thread. If the A/C is off, why would there be cool air coming in unless the ambient air is also cool?
With the seats, they are "ventilated", which means you can have air blown through them. They are not air conditioned or "cooled" as some have said. So, it helps to get the A/C running for a few minutes before turning them on. I typically don't turn them on until I have been driving for a while and start developing a sweaty back side.
Old Jun 30, 2022 | 11:32 AM
  #45
Fman2118's Avatar
Fman2118
Please stop it with the common sense. 😜
