Intake flapper door noise
Old Mar 7, 2025 | 12:49 AM
InfraredLexus's Avatar
InfraredLexus
10th Gear
Default Intake flapper door noise
My intake flapper door makes a plastic on plastic noise when I cut the car off and I was wondering what I might be able to do to stop it, sometimes I can here it when I’m driving the car in manual since I shift around 3k sometimes when just cruising
Old Mar 7, 2025 | 06:33 AM
arentz07's Avatar
arentz07
You should be able to reproduce the sound by hand when the engine is not running, as the flapper module will lose vacuum pressure and reopen the door.
There should be a strip of adhesive foam on the flapper to prevent such a noise. Does yours have that foam?
Old Mar 8, 2025 | 03:54 PM
Relhok's Avatar
Relhok
I unpluged the wire harness from mine and just put it back without snapping it in place. I like the consistent sound of it open for my daily commute. I spend a lot of time between 2700 and 3200 and opening and closing is kinda annoying to me.
I might plug it back in if I take a trip on the highway just in case it improves mileage and reduces drone.
Eggs
Aug 14, 2024 05:18 PM
Alphaman19
Dec 7, 2020 02:39 PM
richy350
Feb 5, 2020 08:41 AM
Gs3500
Jun 24, 2016 02:42 PM
WhatYaGot
Performance
13
Jun 13, 2007 07:10 PM
