Coilovers
Old Jan 9, 2024 | 11:55 AM
CLUB300's Avatar
CLUB300
Default Coilovers
Just curios to see if anyone has attempted to use 2021+ IS350 coilovers on the IS500? I really dont think that any drastic changes go into these suspension parts just because it has a different engine.
I currently have the RR Racing coilovers that ran about $2300.
I see that there are many options for the IS350 for around $1000 - $1200 range like BC racing, Megan and D2.
I had D2 and Megan on 2 previous Lexus and never had any issues with this and would just like to know if it be worth a try.
The coilovers I have run nice, but cant get rid of a slight knock from the rears even orders new swift springs for stiffer ride and nothing changed.
Removed the rear and currently using the lowing springs from RS-R in the rear and kept the RR Racing coilvers in the front because they have felt great up to now, but do not want to continue using springs in the rear and coils in the front since it defeats the purpose of what I spent on coilovers. I am willing to try Megan or BC, but if anyone has attempted this please chime in.
Old Jan 9, 2024 | 12:32 PM
cp2's Avatar
cp2
Veteran: Air Force
have you tried getting a hold of @RRRacing and giving them feedback about your set? i'm sure there's a difference in coils over sets between the 2 cars; otherwise they'd advertise the sets could be used for both applications
Old Jan 9, 2024 | 12:45 PM
CLUB300's Avatar
CLUB300
I am thinking it could just be spring load. I really dont think that they will manufacture one for each model.
Old Jan 9, 2024 | 03:47 PM
AmbyBomb's Avatar
AmbyBomb
Please don't run cheap, entry level coilovers like Megans on a luxury car. If all you want is lower, get decent springs.
Old Jan 9, 2024 | 05:47 PM
604GSE21's Avatar
604GSE21
I had BC racing on my old 350 and my other cars I had, nothing wrong with some of the entry coilovers just buy the brand with good rep like BC Racing and have them adjusted properly, but don't run IS350 coilovers on IS500 cuz spring rates for sure is gonna be a different and shock/struts valving is probably different with the extra weight of the V8. You can run it cuz we can't stop you but it'll probably throw the handling off or you'll bottoming out if you hit a big dip on the highway
Old Jan 9, 2024 | 09:19 PM
Meraki Autoworks's Avatar
Meraki Autoworks
Your #1 Lexus Vendor
V8 vs v6 engine, not worth the difference because of spring rates.
We've been doing RSR coilovers for IS500 owners.
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Old Jan 10, 2024 | 05:46 AM
CLUB300's Avatar
CLUB300
I already have the coilovers from RR Racing which I paid around $2300 for, but I still feel like the rears have a slight knock that for most car people it will go un-noticed, but for me it sounds like something is loose.
It is only the rear. RR Racing did replace the strut from the original and it went down significantly, but after they settled in it got a little louder. Then ordered lower spring rate springs from swift recommended by RR Racing and swapped it out, but the knock is still there.
I removed the rear coilovers and mounted the RS-R lowering springs in the rear and kept the front coilovers for now.
No noise at all, but I want to ride with the full coilover set because it just feels way better.
So I was just curios to see if anyone tried any other brand and what was their experience.
Old Jan 10, 2024 | 05:48 AM
CLUB300's Avatar
CLUB300
-Josh
Has anyone complained about any noise coming from the rear?
Maybe since the RR Racing do not include the divorced spring it adds more weight creating the knock?
Can you send me your contact info so I can ask a few more questions?
Old Jan 10, 2024 | 09:02 AM
Meraki Autoworks
Also make sure everything was installed correctly, sometimes loose bolts make clunking noises.
-Josh
__________________
Orange County, CA
Old Jan 10, 2024 | 11:08 AM
CLUB300's Avatar
CLUB300
Yes numerous times and I know its the coilovers because when I put the lowering springs back there is no noise at all and sounds like factory.
Old Jan 10, 2024 | 11:10 AM
CLUB300's Avatar
CLUB300
-Josh
picklebush
RC - 1st Gen (2015-present)
May 15, 2023 10:18 AM
Gtgerald
RX - 4th Gen (2016-2022)
Nov 29, 2020 08:13 AM
soleeasii
Suspension and Brakes
Jun 11, 2013 12:12 AM
stantu2
Apr 19, 2012 04:12 AM
kloh7
Aug 22, 2007 09:42 AM
