Fuel pump
Old Jul 30, 2023 | 06:01 AM
  #91
Mydogboo12's Avatar
Mydogboo12
Default Fuel pump
Does anyone know the wire hooked up to my 20v fuse is used for this wire was used for my under-glow lighting my lexus mechanic thinks that it might of damaged my fuel pump because it should of not been hooked up to that fuse.
Old Jul 30, 2023 | 11:42 AM
  #92
604GSE21's Avatar
604GSE21
what does the fuse cover say? it should tell you what fuse is for what when u flip the cover upside down
Old Jul 30, 2023 | 01:08 PM
  #93
Kanpai's Avatar
Kanpai
The wire hooked up to the fuse is a poor attempt at wire tapping.
Old Jul 30, 2023 | 11:14 PM
  #94
macmaster's Avatar
macmaster
I honestly don’t understand your question at all. This is why it’s so important to learn grammar and syntax in elementary school.
Old Jul 31, 2023 | 04:34 AM
  #95
AmbyBomb's Avatar
AmbyBomb
He installed underglow, on a luxury car, and it may have buggered up his fuel pump due to the tap job shown.
Underglow, not even once.
Old Jul 31, 2023 | 04:51 AM
  #96
macmaster's Avatar
macmaster
I know the background but thanks. You know what, I’m done trying to help this guy lol.
Old Jul 31, 2023 | 06:37 AM
  #97
snowyblue's Avatar
snowyblue
the lexus mechanic should know what its hooked up to, or have techstream to look at a wiring diagram. he should not "think" its the problem, unless they are not actually diaging the real problem
Old Jul 31, 2023 | 07:21 AM
  #98
Kappa500's Avatar
Kappa500
Says "washer" on the cover.....
I would remove it until you can get is safely tapped... especially if you're having any other issues with your car.
Old Jul 31, 2023 | 03:33 PM
  #99
DLPTony's Avatar
DLPTony
Goodness.
Old Aug 1, 2023 | 04:15 AM
  #100
jsch222's Avatar
jsch222
This “under glow” job is incredible. Look at the gauge in wire and how it changes under the electrical tape. I’d guess they didn’t use heat shrink tubing or soldering. It’s a rig job to put it nicely. I haven’t seen anything this unprofessional since I was 16 and my friends were installing stereos in their own cars without their parents knowing. I would not be surprised, and hard to argue, Lexus denying any warranty work.
Old Aug 1, 2023 | 09:08 AM
  #101
95bat's Avatar
95bat
Agreed. It also looks like they bit the end of the wire off with their teeth and crammed it into a fuse.
Old Aug 3, 2023 | 06:24 PM
  #102
jororo's Avatar
jororo
Probably best to close this thread for the reasons mentioned by @macmaster, @jsch222 and @95bat … surprised the original poster, after posting about this on another thread and getting very negative feedback, created yet another thread to this wiring atrocity. Getting to the point of trolling to be honest.
Old Aug 3, 2023 | 08:03 PM
  #103
macmaster's Avatar
macmaster
I don’t think he’s trolling based on what I can tell from his account. I don’t really mind bc this is the most riveting story yet on the ClubLexus IS500 page. My only complaint is he doesn’t respond much to keep us updated.
Old Aug 4, 2023 | 07:13 AM
  #104
arentz07's Avatar
arentz07
@Mydogboo12 Let me know via direct message if you want the thread to be reopened.
Old Aug 9, 2023 | 02:46 AM
  #105
Mydogboo12's Avatar
Mydogboo12
Default Update On Car Repairs
Hi Everyone
As I have mentioned before I have been without my car since June 30th my fuel pump should be In this Friday and the o ring on Aug 16th the other 2 misc parts are In. The head mechanic at my dealership says upon Inspection he will be able to tell If my under-glow lighting damaged my fuel pump. Will keep you Informed on the outcome.
