Intake system
LOL you get it. Exhaust is cool since stock bolts right back on... I thought this might too. Oh well!
lol its a piece of plastic i will gladly replace if needed cant be more than a $100 bucks. JUST LOOKED IT UP ITS A $54 PIECE OF PLASTIC
I understand about the why. It is the hole cutting I am trying to understand. I looked at mine and air can easily come from below in the grill area. I see where a duct could be fashioned to bring the air right up to it. Is the hole irequired for the air to pass through? I could even see adding some nice insulation to further isolate the engine compartment. I have been thinking about getting one of these for a couple of months now.
Never thought it was rocket science. If the slice is cut for the piece to fit, that is what I thought all along. I go back to my original question and that is why not slightly trim the carbon fiber plate. I'll move on. No grief here.
Just a little clarification on some of the posts here.
First, let me apologize to anyone who has called in and got any unfavorable answers or outcomes. I can assure you it was not me that you spoke to. I have been with RR Racing for around 2 years and have not had any complaints about customer service that I am aware of. It is possible you may have spoken to Simon.
The plastic trim definitely needs to be cut for our heat shield. This is not to get the product to fit, rather it's a main characteristic of the design and cooling improvement. You will shield heat from the engine compartment and pull cool air from the inner fender as well. Without the heat shield, we've seen an intake air temp rise +27* when the flapper door opens. With the heat shield in place, on a back to back run, the IAT only rose +5*. You can not log these gains on a dyno while sitting still with the hood open. But this should equate to some hp down the road with airflow.
Regarding the plastic inner fender. I had an IS500 customer pick up a spare for around $35 at the dealer to cut and store away his original. I'd say 99% will just cut the factory one and not think twice.
If you want to discuss this any further you are welcome to give me a call on the main number. Ask for Justin. If you are local you should come by and check out the shop anytime.
Thanks
-Justin
RR Racing | Sales
Thanks
-Justin
RR Racing | Sales
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
I have been looking at this some more. Looked under the hood at MYIS500 and see some cool things and ways to improve the efficiency of this heat shield. First thing is that once the heat shied is in place like the pic above, if you look on either side of the airbox in the pic or on your own car, there is lots of space for hot engine compartment air to make it into the intake. This can be eliminated by using some quality dense foam insulation in these areas to close off the area for hot air to enter. The space is considerably large. The next thing I saw is the area where you are to remove some of the plastic liner for the heatshield to fit and draw air from the fender well. I peeked into this area and there simply is a limited area for restricted air to make into the intake. The better location for the air to enter is straight down in front of the airbox. Looking there you can see down into the bottom of the grill. There you will see the smooth back side of some plastic that is mounted (possibly by some screws Ii see) to the front apron assembly. Down this channel has more useable cool air for the intake with the insulation around the box. The smooth black plastic I am speaking of covers what is otherwise a wide open grill. I am talking about the small grill on either side of the main grill. In this case, the one on the passenger side. I need to explore how to remove this plastic cover to open up that grill. If you push on the plastic behind this grill you will see it is not solid and one piece with the grill. They are two separate pieces. With that back black plastic sheet removed, lots of cool outside air can come through and up to the intake box. I did not see this posted anywhere else in the IS 500 thread, so I thought I would share. If someone has visited this already and knows more please share. I am contemplating options that are minimally intrusive. Most notably, not cutting the plastic, but adding the insulation.
