Question on 2023 IS 350 automatic
Old Dec 13, 2022 | 04:15 PM
rVague's Avatar
rVague
Default Question on 2023 IS 350 automatic
Just got a new 2023 IS 350 and I have a question about the transmission in Sport mode. I notice that at around 75 mph it stays in 6th gear at around 3000 rpm and doesn’t upshift to 7th or 8th. In my 2017 GS 350 F Sport it would up shift to higher gears. Is this normal for the IS. It does not have Sport +.
Thanks in advance.
Old Dec 13, 2022 | 05:39 PM
iamcc88's Avatar
iamcc88
Thanks in advance.
There was a post about this recently and I think the answer is that you need to put it into manual mode and manually go into the higher gears. If not, the behavior you describe is normal.
Old Dec 13, 2022 | 06:12 PM
HeadShot's Avatar
HeadShot
Thanks in advance.
RWD or AWD?
Old Dec 13, 2022 | 08:24 PM
rVague's Avatar
rVague
Originally Posted by HeadShot
RWD or AWD?
It is rear wheel drive
Old Dec 13, 2022 | 08:28 PM
richieca's Avatar
richieca
Interesting I guess Lexus thinks gear 7 and 8 is just for gas saving.
Old Dec 14, 2022 | 07:03 AM
FH212's Avatar
FH212
My 21 is the same way. If you are on the highway and need the higher gears just set it to "Normal". I only use the Sport setting driving around town and city. Highway is Normal mode.
Old Dec 14, 2022 | 09:16 AM
arentz07's Avatar
arentz07
Same. Sport mode pretty much never goes into 7th gear or 8th gear for me.
The idea is, you're using Sport mode if you're in the turns.
MM8419
RX - 3rd Gen (2010-2015)
Aug 11, 2021 01:45 PM
burnik
ES - 7th Gen (2019-2025)
32
Dec 24, 2019 08:33 AM
toystry
RC - 1st Gen (2015-present)
33
May 27, 2015 02:06 AM
mikesj
Apr 4, 2015 02:51 PM
DVac3
Jan 13, 2008 08:40 PM
