B2311 code
Old Nov 23, 2022 | 02:08 PM
sunamer's Avatar
sunamer
Default B2311 code
Recently during code scan, I noticed B2311. I initially assumed it would go away but it is still there. 3-4 scans later (and 1-2 months later)
Anyone knows any specifics pertaining to the code, conditions and remedies? All windows are opening and closing without issues.
Old Nov 23, 2022 | 08:54 PM
ex00's Avatar
ex00
Either the window regulator motor assembly is malfunctioning or the ECU for the regulator determines the window is off track/position from normal operating conditions. The deviation listed is 20mm or more from normal position.
If you have Techstream, you can try to reinitialize the power window control system to see if that helps gets things back into place.
Old Nov 24, 2022 | 06:04 AM
sunamer's Avatar
sunamer
why would 3 out of 4 windows have this issue simultaneously though?
Old Nov 24, 2022 | 10:16 AM
ex00's Avatar
ex00
That I am not too sure, did you have any of the windows tinted or something along the lines of having them removed or the area worked on?
All three will have the below conditions and troubleshoot in relation to their respective sides:
  • Power window motor malfunction - conditions met:
    • power window regulator motor assembly is malfunctioning
    • ECU for power window regulator motor determines the window position has deviated approximately 20mm or more from normal position
  • Troubleshoot:
    • incorrect installation of power window components
    • overheated power window regulator motor assembly
    • wire harness or connector
If you had either conditions below:
  1. Power window regulator motor assembly replaced with another one; removed and reinstalled - initialize the power window control system
  2. Inspect fuses for circuits relating to the system
You can try to initialize the system again if you have Techstream of know someone who will let you use it. Clear the DTCs first, roll down the windows and try to lube/grease the window rails. Then find each regulator assemblies and reconnect all harnesses to the system. You may inspect the end connectors to see if there are any damaged or oxidized areas. I think someone sprayed some WD-40 into their radio unit connectors since they were getting some issues. If you do go this route, I would pick up electronics contact cleaner and some should have a solution with the cleaner that lubes/greases the contacts after cleaning at the same time. DeoxIt makes something for this on electronics.
Old Nov 24, 2022 | 11:45 AM
sunamer's Avatar
sunamer
  • Troubleshoot:
windows were tinted... by the original owner. I had this car for 4 years, and until recently there were no issues with that code at all.
I usually scan my car at least once a month so it would have popped up. I dont have a techstream, but several months ago Lexus dealer inspected the car and did not find this code either.
  1. Inspect fuses for circuits relating to the system
That might be something to look into. I doubt all 3 motors can fail at the same time.... or all 3 windows can "misalign" at the same time. But a fuse could explain such a coincidence
Old Nov 24, 2022 | 01:20 PM
ex00's Avatar
ex00
Ah ok. Well windows over time can get out of sync or alignment, with more tech on a car it's just prone to more issues with all the sub systems integrated for almost everything. If the windows are working then that could just be a loose connection, I know some tint shops depending on the installation. They will remove the door panels off to access the windows to be able to reach the full glass for a better installation and be able to use the windows within a few hours in the sun. You can also see if you can slightly move the affected windows up to check if they are sitting properly.
I've made it a point to lube/grease the channels a little bit every 6 months when I do a total wipe down of the door jams. Just something that was pointed out by YouTube mechanics on prolonging window motors and making sure there isn't much resistance when the windows slide. I believe you want to get white grease and WD-40 makes a special one in a silver can I believe with an attached spray nozzle straw. You can also get grease that is more universal for door hinges and other places that you might want to regrease over time.
I know you probably are thinking about it too much, I felt the same when the HVAC system was getting funky for a month and after Techstream I was able to reset the system to get it back in working condition. If you have a spare laptop with Windows 10 64-bit, you can repurpose it as a Techstream laptop to be able to perform in-depth diagnostics and self-checks to any subsystems.
Old Jan 1, 2023 | 02:22 PM
sunamer's Avatar
sunamer
I found fuses for all four door window actuators and just pulled them and installed them back. It looks like the issue has not returned yet since then.
Old Jan 14, 2023 | 06:14 PM
sunamer's Avatar
sunamer
Just to re-affirm - I reran the scan and this code has not showed up yet.
One caveat - I was pulling those fuses while car was one step away from starting engine ignition wise. Dont know if it matters, but gonna leave it here anyway.
RegBeach
Nov 28, 2019 02:07 PM
u082gs300
Jul 19, 2015 03:35 PM
oneshote
RX - 1st Gen (1999-2003)
Dec 17, 2010 01:03 AM
vwynn
Apr 18, 2009 05:05 PM
