3IS heated steering wheel
Old Nov 8, 2022 | 08:46 PM
Lex_Giorgio's Avatar
Lex_Giorgio
Default 3IS heated steering wheel
Has anyone successfully added a heated steering wheel to a 3IS that did not come with it?
If so, besides finding a heated steering and the button to turn it on/off is there anything else required?
Thanks!
Old Nov 8, 2022 | 09:26 PM
Droth's Avatar
Droth
Need to change controller in the steering wheel, and I had to add wire from clock spring to switch panel
Old Nov 9, 2022 | 05:48 AM
swaangin's Avatar
swaangin
A lot of the carbon fiber steering wheels come with the heated coils so that shouldn't be a big deal. As mentioned above, probably need to run wiring from the steering wheel and add a switch
Old Nov 13, 2022 | 08:58 PM
Lex_Giorgio
Which controller?
What year is your car?
I was hoping it would have been prewired (like the models that don't come with a backup camera, have the wires there from the factory).
Old Nov 14, 2022 | 01:18 AM
Droth's Avatar
Droth
Originally Posted by GeorgeR
Which controller?
There is a wee controller in the steering wheel itself, that the heater elements connect to. Wiring is in the clock spring, its was a single wire I had to add from clock spring connector (steering column) to the switch connector (same connector that does seat heater switches)
I got a used steering wheel with controller etc in it.
Mine is a 2017 350 F Sport
Old Nov 14, 2022 | 05:14 AM
Lex_Giorgio
Perfect thanks!
If you happen to have more info on which pin this wire goes to, that would be great!
The steering wheel that you got is a 2017 as well?
Old Nov 14, 2022 | 04:07 PM
Droth's Avatar
Droth
Wheel I got was from an 18 RC. It was actually 2 wires between steering column and switch. See attached PDF. The relay and all other wiring was already there.
File Type: pdf
Old Nov 14, 2022 | 09:23 PM
Lex_Giorgio
Thank you!
Does your car have lane assist?
Weird how the car would have the steering heater relay, but not the wiring for it.
Old Nov 14, 2022 | 09:42 PM
Droth's Avatar
Droth
Yes has lane assist, I was suprised relay was there as well
Old Nov 15, 2022 | 06:36 PM
Lex_Giorgio
I asked about the lane assist because that vibrates the steering wheel. The lack of 2 wires is a bit weird... but good to know!
Thanks again!
Old Nov 17, 2022 | 11:56 PM
Sonn's Avatar
Sonn
You should do a video tutorial on this
Old Nov 18, 2022 | 06:43 AM
Lex_Giorgio
I will, I just have to find a heated steering wheel first haha!
Old Dec 15, 2023 | 10:18 PM
Lex_Giorgio
This links in the PDF don't work.
Did you take photos of what had to be done?
Thanks again!
Old Jan 23, 2024 | 07:27 AM
Lex_Giorgio
Update:
My car is a 2017 IS 200T with lane assist
Here's the 2018 IS350 F Sport heated steering wheel with lane assist
Theirs a controller in the wheel (allows it to vibrate (for lane assist) and controls the heating):
- 864A1-48011 (2nd pic is an IS500, 3rd pic is the 2018 IS350)
I haven't removed my 2017 steering wheel yet, but that module should be there since I have the lane assist which vibrates the steering wheel.
Old Jan 23, 2024 | 07:31 AM
Lex_Giorgio
Here's an RC that does not have heated steering wheel and it's missing that module since it does not have lane assist, so this may be the wiring that Droth is referring to:
