Door panel inserts is250 3is
Old Sep 4, 2022 | 08:28 PM
Jaydm's Avatar
Jaydm
10th Gear
Default Door panel inserts is250 3is
Does anyone know if the door panel inserts are interchangeable between the is300 and the is250?
My leather started peeling and need one last insert panel to complete my replacement. Found an is300 insert which is same trim but not sure if there are any differences?
Old Sep 4, 2022 | 09:05 PM
Coconut's Avatar
Coconut
Assuming the color is a match, the shape and mounting points should be exactly the same.
Old Sep 4, 2022 | 11:37 PM
Jaydm's Avatar
Jaydm
10th Gear
Thanks for the response. Trim color code is the same. Going to order and will post back confirming your response. Sucks that my trim panels started peeling but fortunately found three brand new ones online for every side but the front passenger
Old Sep 9, 2022 | 10:16 AM
Jaydm's Avatar
Jaydm
10th Gear
I can confirm for others that the is300 and is250/350 door trim panels do match for 2014-2016 models. Direct swap (may need to change your anchor plugs as they could be different sizes).
The part numbers on the inside of the panels were the same despite lexus parts telling me otherwise.Though, the interior trim codes were a bit tricky trying to match with the stickers on the inside of the door panels. My trim code was EA04 (0XN-A1 Parchment) but is300 part from EA04 trim code came out as (OXN-B1 Parchment) and my other panels were (OLA-B6 Parchment).
Markvel
Sep 22, 2021 11:10 AM
seanmwple
Sep 4, 2020 07:56 PM
Skgilmore
May 13, 2018 10:03 PM
incvn
Aug 15, 2016 10:35 PM
lexusgeek
Apr 10, 2007 09:30 AM
