How to remove map/dome light console
Old Jul 8, 2022 | 10:44 AM
Chris350F's Avatar
Chris350F
Default How to remove map/dome light console
Hi Guys and Gals,
I’m interested in removing the overhead dome/map console on my 2020 IS to wrap it. Does anyone know how to remove this part?
I've been looking online with some Google searches, here on the forums and YouTube but no luck.
Any help us appreciated! Thank you!
Old Jul 9, 2022 | 05:16 PM
ex00's Avatar
ex00
The clear plastic can be removed by locating the 2 corners that have slight indent tabs that you can use a trim removal tool to wedge in and pop out the clear plastic. For the overhead these instructions for the RX should be similar (
Old Jul 9, 2022 | 10:31 PM
Chris350F's Avatar
Chris350F
Originally Posted by ex00
The clear plastic can be removed by locating the 2 corners that have slight indent tabs that you can use a trim removal tool to wedge in and pop out the clear plastic. For the overhead these instructions for the RX should be similar (link)
Thank you! I appreciate it!
Old Jul 12, 2022 | 12:38 PM
robsta8886's Avatar
robsta8886
Originally Posted by Chris350F
Hi Guys and Gals,
So the whole map light assembly is held in by 4 plastic body clips. 2 toward the front and 2 toward the rear of the assembly. Pull the front of the assembly first. After the clips are disengaged, there are two wire harnesses that need to be disconnected, one on each side.
Old Jul 14, 2022 | 01:00 PM
Chris350F's Avatar
Chris350F
Perfect! Thank you so much! I’ll try that either today or tomorrow.
05ls430518
Jun 24, 2020 03:02 PM
Tensi
Sep 28, 2007 06:33 AM
carlos
Jan 15, 2007 01:10 PM
