Fix for Infotainment Rebooting problem?
Old Jan 23, 2022 | 12:38 PM
Kaianuanu's Avatar
Kaianuanu
Default Fix for Infotainment Rebooting problem?
Just bought a 2015 IS350 with 55k miles yesterday from a local Toyota dealership. Was incredibly disappointed on the ride home to realize it had this awful issue with the head unit constantly rebooting? I was just wondering if there has been a fix for this issue yet? If so, what kind of repair bill would I be looking at? Also, are there any aftermarket workarounds like android auto or car play units or anything like that that may be more affordable? I’d really hate to have to return this car over such a stupid issue. I’m getting ready to sit down with someone at the dealership now to talk about it. And yes I have been reading threads on here looking for my answer but haven’t found it yet.
Old Jan 24, 2022 | 05:26 AM
Sasnuke's Avatar
Sasnuke
There are more than several threads on here about this and similar issues.
I'm assuming you haven't read them all yet to see all the proposed fixes to this.
Ultimately the issue is the radio that is causing this...and it you're lucky, you might be able to fix it without replacing parts or it costing anything...but there is a high probability the radio will need replacing.
You mentioned aftermarket units as a workaround...those units piggyback on an already fully functional radio, so no, they would not work.
Things to try:
1. Hard reboot...hold down the radio power **** (the one on the left) until the system reboots, probably about 20 seconds or less
2. Disconnect the battery for at least 30 minutes and reconnect
3. Disconnect the battery for 30 minutes, remove the micro SD card from its slot in front the shifter, then reconnect the battery. When the system finishes booting up, insert the micro SD card
There is a chance with number 2 and 3 above that the rebooting will stop, but you'll also end up with just a blank(black) display screen.
The display is just a monitor for the radio...so the issues you are having have nothing to do with the display, it's all about the radio.
Old Jan 24, 2022 | 06:25 AM
wthrman2's Avatar
wthrman2
^^ Great tips as always. That is why I always do extensive research on car forums before I buy a car and see what are the potential issues with them to avoid a nasty surprise.
Sango
Dec 31, 2010 01:16 PM
Deros
GX - 1st Gen (2003-2009)
Sep 12, 2010 09:57 PM
TLDriver
May 29, 2008 02:18 PM
filhiol
Dec 6, 2006 07:59 PM
nostart
IS - 1st Gen (2001-2005)
Dec 21, 2001 01:48 PM
