Lexus wheel spec
Old Jan 6, 2022 | 01:33 PM
Easyf's Avatar
Easyf
7th Gear
Default Lexus wheel spec
Hey guys. I currently drive a 18 Lexus is300 AWD Fsport if that matters. I am currently looking at a set of wheels that’s 18x8.5 with +33 off set on all 4 wheels and I’m putting 225 in the front and 255 in the rear. I was wondering if I would be able to fit that. Suspension and everything is stock.
Old Jan 6, 2022 | 01:44 PM
CASeoul's Avatar
CASeoul
Originally Posted by Easyf
Hey guys. I currently drive a 18 Lexus is300 Fsport if that matters. I am currently looking at a set of wheels that’s 18x8.5 with +33 off set on all 4 wheels and I’m putting 225 in the front and 255 in the rear. I was wondering if I would be able to fit that. Suspension and everything is stock.
The 225 would fit on a 8.5, although it'd be stretched
The 255 would also fit
If you could tell us the aspect ratios as well, I'm sure @Sasnuke will give you a definitive answer.
Are you just trying to reuse the stock tires?
Since you're squaring up the wheels anyway, I'd recommended going square for rotations.
Old Jan 6, 2022 | 01:49 PM
Answer's Avatar
Answer
They will fit, i'm running those specs lowered on RSR Downs (that's assuming the spoke pattern will clear the brake calipers)
I'm also running stock tires sizes without any issues on that setup. So as long as they clear the brakes, you're good to go (keep in mind, if you are AWD, you need to make sure the overall diameter will be the same on all 4 corners).
Easyf's Avatar
Easyf
7th Gear
Yup! I am trying to reuse the stock tire
Old Jan 6, 2022 | 01:50 PM
Answer's Avatar
Answer
You'll be fine, see my previous reply.
Old Jan 6, 2022 | 01:52 PM
Easyf's Avatar
Easyf
7th Gear
yup! Just saw it. Thanks! I am purchasing rays gramlight 57xtreme. Saw them locally for a pretty good price. Bolt pattern is 5x114.3 which should be same to my car
Old Jan 6, 2022 | 01:53 PM
CASeoul's Avatar
CASeoul
Answer's got the answer for ya, just make sure about the AWD thing they highlighted.
Old Jan 6, 2022 | 01:55 PM
Easyf's Avatar
Easyf
7th Gear
yea, it’s AWD. So the rim will fit , I just gotta make sure that the tires diameter are all the same ?
Old Jan 6, 2022 | 02:02 PM
Easyf's Avatar
Easyf
7th Gear
Just to be sure. My front tires are 225 40 18 and the rear are 255 35 18
Old Jan 6, 2022 | 02:10 PM
Answer's Avatar
Answer
That's stock size, you're good!
Old Jan 7, 2022 | 03:25 AM
swaangin's Avatar
swaangin
Technically, isn't OP shrinking the diameter of the wheels because he is using a half inch wider wheel with stock tire sizes?
Edit: Nvm, the rear tire is the same size, the front would be a tiny bit smaller but I don't think it would effect the AWD system
TdotIS300F
Sep 3, 2020 06:55 AM
mceagle555
GX - 2nd Gen (2010-2023)
Apr 25, 2020 09:52 PM
FredyGutz
Jul 26, 2018 03:25 PM
GenEric587
Apr 13, 2017 10:25 PM
g_abac
Mar 2, 2009 10:51 AM
