2016 16" Steel Winter Wheels?
Old Sep 29, 2021 | 10:51 AM
gregmcm's Avatar
gregmcm
Default 2016 16" Steel Winter Wheels?
Have a 2016 IS300 with 17" wheels. Question: would anyone know if there would be 16" steel rims available that would fit the front and clear the large calipers? Asking as I have a new set of 16" winter tires on steel rims but the rims won't clear the front calipers. Thanks
Old Sep 29, 2021 | 12:29 PM
Sasnuke's Avatar
Sasnuke
Welcome to the forum!
I was never able to find a set of 16's to fit the IS with the large calipers.
When my 250 had the stock front brakes you could get 16's to fit...in a steel wheel.
But once I installed the larger brakes, forget it...it wasn't even close.
A used set of 2IS 17's is what many use for winter...they will fit over the large brakes.
Old Sep 29, 2021 | 12:43 PM
Lwerewolf's Avatar
Lwerewolf
If the calipers are the same as the IS350 (the monoblock 4piston ones), you will need to choose specific 17s (like the stock ones) to fit. 16s are not an option.
Old Sep 30, 2021 | 11:21 AM
gregmcm's Avatar
gregmcm
Thanks for the reply.
Old Sep 30, 2021 | 11:22 AM
gregmcm's Avatar
gregmcm
Thanks for the info
Old Sep 30, 2021 | 05:47 PM
m1919's Avatar
m1919
You could sell the set of 16s, put winter tires on your stock 17s and get some 18s for summer
Flash5
Feb 6, 2020 08:15 PM
DZJ
Dec 12, 2010 12:27 PM
RudeDoggy
Canada
Nov 14, 2008 11:56 AM
c5mtl
Oct 31, 2006 05:31 AM
c5mtl
Oct 11, 2006 04:12 PM
