Cluster swap with F sport
Since the Lexus dealer installs after market intakes, exhausts, and mods.. Is it possible for them to swap the base model cluster with an F sport one-if I bought one?
I’m not sure, but ID suggest you try DIY. It’s a 30 minute job with basic tools
have you tried this before? If so we’re there any warning lights on the clusters popping up afterwards? I don’t want to void my warranty if anything goes wrong-which is why I was wondering if a dealer could do it
Huyxxj (06-07-21)
There was someone on the forum and on eBay selling pre-programmed clusters for around a couple hundred bucks. He made sure it was compatible with your car model to avoid any warning lights. Dealer going to charge an arm and a leg for it
Huyxxj (06-07-21)
i would definitely install myself, but I have no experience messing with the interior stuff. I couldn’t find any guide or video for the 3rd gen IS. If there is I might do it myself.
Huyxxj (06-07-21)
So this guy has an RC-F, but it should be the same process. He cracks me up, I swear he takes apart his dashboard in half his videos.
Should give you somewhat of an idea what's involved at least getting to the cluster. (skip ahead to like 3:35 to get to the dash removal)
https://youtu.be/ohqDSpuOk7E?t=218
You need to be absolutely sure that ther cluster you buy came from the same year model of your car, and if it does or does not have navigation. If the year and that option match, it should be plug and play
It's funny you bring this topic up, I'm actually doing this swap myself, today lol. My cluster is being delivered today, I'll let you know how it goes.
You need to be absolutely sure that ther cluster you buy came from the same year model of your car, and if it does or does not have navigation. If the year and that option match, it should be plug and play with no lights.
yeah it's a pain to find a cluster that matches your year and option, especially since a lot of the ebay sellers list it as fitting 2014-16, when, at least in the base to f-sport swap scenario, it is not plug and play unless it's same year, so you have to find a seller that lists the donor vehicle specs
sqlboy2000 (06-07-21)
The milage is stored on the cluster, after I install it and confirm everything is working properly I will take it back out and send it in for a milage and vin correction service, like this one, or similar: https://www.taninautoelectronix.com/...ge-correction/
Will do!
Will do!
Also, I seriously doubt a dealership will do this for you unless you are cool with a tech or service manager.
The part # on the F-Sport cluster will not say it's compatible with the base model, even though it is (if same year), in their computer. At least my dealership, idk about others, will refuse to install anything that their computer tells them is a not a correct matching part #.
Also, a dealer only orders new parts, so unless you are driving a semi new IS, I doubt they could even order, lets say a 2014 new model cluster.
Luckily removing the cluster in our car is a 10 min job
probably just gonna go with this one. It’s a year previous than mine-but the closest one I can find. I think I might bring it in to the dealer if they can do it for around 200, I should have free service with the dealer still. https://www.ebay.com/itm/25494986545...IaAk6JEALw_wcB
BUT you will likely get dash lights and things not working since it's not the same year... or even model. Even though the plugs are the same, the pins are in different locations from year to year and model to model to model. Closest you can find is not gonna work with this swap. Keep looking. Do not buy this.
