How to disable auto-upshift without turning traction control off
Same as above, when in Manual Mode car never shifts by itself. IS 200t 2016 Europe. And the nannies are ON.
This really sucks, to have the Manual mode but no full control.
Can you try to put it in Manual mode, (Sport and/or Sport+), and then do a couple of shifts with the lever before attempting to check for rev limiter? Maybe this would work like I've seen on other cars.
Thanks for the suggestion. I will try that, see if it makes a difference.
Cheers
When I see post about shifting past redline on this 3.5 Motor I always wonder why?
At Redline with or without some bolt on mods at Tops the 3.5 starts losing hp and declines at 6300 - 6600 rpm's where it has reached it peak hp.
After this rpm it just steadily declines in hp. Even some Tunes shifting at 7300rpm are scary, to me anyway. Makes me wonder why someone would want to go to peak hp, keeping spinning to possibly over Rev beyond Cams breathing capability, and then shift when the car has declined in hp and still steadily declining in hp and making less hp? IDK, but maybe I don't understand the desire of this? Do this in a close Race and you will for sure lose and get beat.
I get where you're coming from. However, I'm not actually trying to push past peak power or to the absolute rev limit of the engine. I'm actually happy to have a fairly reasonable redline because I'm not trying to squeeze the absolute maximum out of the engine like I'm in a race. The problem is not the actual redline, it's the automatic upshift near redline that I have an issue with, because I can't rely on the consist throttle response and effect on the balance of the car in the corner - basically I'm not thinking about anything apart from the accelerator and brake pedals and the steering wheel input. When the car suddenly changes gear in the middle of a corner or in the middle of a series of corners, I'm forced out of the zone of enjoying the car's balance and I now have to either force the car back into 2nd gear or re-evaluate how to handle the car in 3rd gear now. Basically I don't have control over the car.
Even in a racetrack situation, let's says in a quick series of back-to-back corners, peak power is not what keeps a driver in the same gear at or near the redline, it's actually because all the driver wants to do is focus on where to place the car using the throttle and steering, keeping the car balanced and moving smoothly through the corners - pausing to change gear will upset the balance of he car and take brain power from the quickest line through, so actually would cost more time than simply staying in one gear and focussing on the cleanest line through those corners. And sometimes you want to drop from up high in one gear, right into the power band in the next gear, which may require higher revs in the previous gear to "fall back" into the right rev band in the next gear. So sometimes having a redline higher than peak power is useful.
I hope I'm making sense.
In normal "D" drive, my 2016 IS did the same thing. It would upshift at 6200 or 6300 RPM. If I went into "M" manual shift mode, it would hold all the way till 6600 RPM.
I actually did get to experiment a little yesterday since the roads were quite wet here... And yes, I did feel a slight bit of oversteer when I really tried.
The TC kicked in pretty early. Obviously I wasn't at full throttle because I am trying to be nice to the car until the break-in period passes.
Those are wider tires than stock (225/40R18 front, 255/35R18 rear), right? I wonder if they fit the wheels differently and influence the handling... Obviously, not all tires are made equally, but a 235 is going to be wider than a 225 no matter what.
The 235's in the front make a big difference even with the stock tires on the 2021. It feels super planted.
Yeah, it's a good point you raise. The stock rims allow up to 245 wide fronts (8 inch wide) without any issue, but the rear rims only fit the standard 255 wide tyres (8.5 inch rims). In order to maintain the same rolling diameter for both front and rear rims while still increasing the width, I fitted these after checking what effect this would have - my speedo is slightly more pessimistic than before, otherwise no issue, although of course I can't see what the rear contact patch looks like when under full load
My experience is the same, front end has plenty of grip, rears could definitely do with more rubber but I'm not going to change the wheels. I believe that the arches could probably only fit 275s anyway so will have to be happy with that.
I think so, if TC was fully-off, though I could be wrong. The overall drivetrains in the ISes haven't changed a ton since 2006
The TC kicked in pretty early. Obviously I wasn't at full throttle because I am trying to be nice to the car until the break-in period passes.Those are wider tires than stock (225/40R18 front, 255/35R18 rear), right? I wonder if they fit the wheels differently and influence the handling... Obviously, not all tires are made equally, but a 235 is going to be wider than a 225 no matter what.
I believe this is part of the reason why Lexus made 3rd, 4th, and 5th gear so close together on the 8-speed auto.
None of this applies if you are just driving "normally" though.
There is something to be said for "area under the curve" - the idea being to keep the car in the peak of its powerband for the longest time possible. So, even if you make slightly less horsepower at 7000 RPM compared to 6600, you are still taking advantage of the gearing in your current gear, not to mention being at a higher RPM, closer to peak power, in the next gear.
In these cases each time we were even a nana second because it all it takes delayed or got out of that peak power band by over peaking, you also cause it to drop out rmp's back into a non optimal shifting range also. if you shifted at peak, it dropped back to drive back to peak no loss power. If shifted over you dropped back to continued over shifts that resulted in loss performance in speed and time. This was also impacted by your own personal delayed reaction time to shift with a Clutch or a Auto Manuel shift. Now if you changed Cams and were making more breathing power beyond redline that a different story. I hope I explained this correctly to be understood.
If the point was the delay of the auto Trans map, then I understand. A good ECU Tune can get rid of and change that very easy. You can also pull the Trans fuse and or reset by disconnecting the battery and see if the Trans ECU relearns itself if you drive it aggressively and it will maybe remap some. But for sure there are ppl who want to just let the car over rev to 7500rpm+ cause they think they are making more power and it feels good.
Why I have my 2013 GS350 with the 6 speed auto still!
Hi,
2015 is 250 non f sport. i know that say i'm driving 30-40mph, it won't down shift to gear 1-2.. but if i leave it in those gears and go all the way to the rev limiter, it won't shift 100%. you're putting your car in manual mode right? like moving the shifter to the + / - side, right?
I've never turned off traction control, maybe I'm not taking it all the way to the rev limit? I can make sure again today. I remember I was at a stop and forgot I was in manual mode and had my foot on the gas (thinking it would shift) and it was just revving like crazy and didn't upshift on it's own until I did it.
But why would you turn off traction control? Does it feel better driving when you turn it off?
And i tried to turn it off but for some reason the light wouldnt show up. I then held onto the button a bit longer and both traction and some other abbreviated thing would show up and light up constantly. Like nothing else would show, it will always come up with those warnings and you cant change it to another view setting and have it stay on that view, just goes back to the Traction being off. Is this normal?
NikonGuy
Jun 11, 2015 10:42 PM
