Cd won’t load
Old May 29, 2021 | 04:56 PM
andy350's Avatar
andy350
Default Cd won’t load
I just bought 2016 Lexus is 200t fsport.
Tried inserting cd but it says disc error.
please help.
thank you.
Old May 29, 2021 | 05:18 PM
Jazzrock's Avatar
Jazzrock
Welcome to the forum! I have the same car, bought used in 2019. I love it and use the CD player on occasion. Make sure you're not inserting the disc upside down.
You can also buy a CD player cleaning disc and run it a few times. I Googled it and it works for some. Good luck!
I'm having a Lexion CarPlay/Android unit and 10 inch screen installed June 11.
Old May 29, 2021 | 05:29 PM
andy350's Avatar
andy350
so if i buy a cleaning cd, will it go in...because a regular cd won’t even go in
Old May 29, 2021 | 06:45 PM
Jazzrock's Avatar
Jazzrock
No it won't. There's no other CD in there already? Does it give an error number, as in CD error 1, 2, 3, 4?
Are you trying CD-R discs or commercially made CDs? Try removing the negative terminal on the battery for 15 minutes
and putting it back on. Try a few different CDs to see if they go in. Maybe the CD player is shot and needs replacement.
Hopefully others will chime in with other suggestions.
Old May 29, 2021 | 07:26 PM
andy350's Avatar
andy350
I don’t think any cds in there...I click eject and nothing comes out.
It just says disc error ...no numbers.
Trying to insert regular commercial cds...tried 3 different music cds...does not insert....stays out and just says disc error.
will try removing negative battery terminal tomorrow.
Old May 30, 2021 | 12:56 PM
andy350's Avatar
andy350
Disconnected battery for 15 minutes.
Still did not work.
Same thing happens.
cd goes in less than half way and comes out and says disc error.
Old May 30, 2021 | 01:38 PM
athanato's Avatar
athanato
I assume this was not purchased via a dealer thus you can't utilize a short warranty?
Old May 30, 2021 | 03:33 PM
Sasnuke's Avatar
Sasnuke
Any chance there is something in there besides a disc?
Given the limited space in the IS many use a CD player cell phone mount.
Maybe the previous owner did and piece of the mount is in the player.
Just spit-balling ideas.
Old May 30, 2021 | 06:42 PM
andy350's Avatar
andy350
is it easy to open and see if there is something in there
Old May 31, 2021 | 04:41 AM
Sasnuke's Avatar
Sasnuke
Just to see if there is something in the slot you can look through the same opening the CD slides into.
Gently push the felt material apart look in a flashlight...you might be able to see if there is something in there.
Otherwise the radio would have to come out and completely apart to check it thoroughly.
Old Jun 18, 2021 | 06:35 AM
andy350's Avatar
andy350
At Lexus dealership now.
they said they are going to run diagnostics which will cost $157
i said go ahead
Now waiting for results
Old Jun 18, 2021 | 07:18 AM
sqlboy2000's Avatar
sqlboy2000
i said go ahead
That will pay for like 16 months of a music streaming service, just an idea.
Old Jun 18, 2021 | 07:50 AM
andy350's Avatar
andy350
Lexus said I need a new radio unit that will cost around $2200 and charged me $74.88 for telling me this.
Old Jun 19, 2021 | 07:41 AM
ScytheDC's Avatar
ScytheDC
I mean... are you actually going to listen to CDs? Unless this problem is preventing you from using Bluetooth/USB/Radio/Satellite, there’s absolutely no reason to waste money on this. I’m surprised you paid a dealer $75 to tell you what you already know...
Old Jun 19, 2021 | 10:59 PM
andy350's Avatar
andy350
True…never going to listen to cds
just felt the need to have everything working.
