Front bumper fender gap
Old May 22, 2021 | 02:36 PM
mrjeff51's Avatar
mrjeff51
Default Front bumper fender gap
Any ideas on how to fix this gap on both sides. I tried removing the bumper and realigning it but no luck, might have even made it worse. Would a new bumper help? Current one has some scratches/rock chips anyway.
Old May 22, 2021 | 03:10 PM
swaangin's Avatar
swaangin
It's not bad enough for you to go get a whole new bumper.. you'd most likely be going aftermarket which is $500-600 for the bumper alone (not painted). Looks like the clip isn't sitting right, try really pushing it in. Did you hit something?
Btw can you send a pic of your car side profile? Wheels look fire
Old May 22, 2021 | 05:22 PM
mrjeff51's Avatar
mrjeff51
I tried to push it in real hard but it wouldn't click into place; couldnt figure out why even after disassembling I didn't notice any clips in that area or broken pieces. I've had my front bumper replaced before through Lexus Certified Collision center who used OEM parts.
And here's a side profile, wheels are nothing fancy, just XXR 559 18x8.5
Old May 22, 2021 | 05:51 PM
Sasnuke's Avatar
Sasnuke
If the tabs on the bumper are not torn, then the issue is likely the plastic clip assembly on the vehicle.
The bumper basically clips/snaps into the clip assembly below the area where the fender and side of headlight meet.
I would try new clip assemblies on both sides first.
If the tabs on the bumper are torn then the bumper is garbage...you can't fix that.
Old May 22, 2021 | 05:57 PM
mrjeff51's Avatar
mrjeff51
Thanks, I'll have the check the clips under the headlights next time I take the bumper off. Any idea of the part number of the clip assembly that sits under the headlights? The bumper tabs look fine so I dont think its that.
Old Jan 19, 2022 | 04:18 PM
Leo7's Avatar
Leo7
any luck ?
i have the same problem on my driver side 16’ IS300
Old Jan 20, 2022 | 10:10 AM
wsvc206's Avatar
wsvc206
Originally Posted by Leo7
any luck ?
You need this to fix it
Old Jan 20, 2022 | 12:16 PM
Sasnuke's Avatar
Sasnuke
any luck ?
I believe this is the part for your 2016...double check to be sure:
https://parts.longolexus.com/oem-par...Y2LWdhcw%3D%3D
Jasoneo5
Apr 17, 2015 03:57 PM
SB350
Apr 26, 2013 06:59 AM
Lohus
Mar 9, 2010 04:54 PM
s6 4rings
Dec 15, 2007 06:18 PM
