2017 lexus is 200t tpms sensor reprogram issue
Old Nov 15, 2020 | 02:32 PM
Johnny96's Avatar
Johnny96
Default 2017 lexus is 200t tpms sensor reprogram issue
I recently took my car to a tire store to get a new tpms sensor and when they tried reprogramming it it didn’t work. And on my gauge cluster the screen for the readings is blank for all the tires. They tested all my sensors and they all work. So i took it to lexus to see what was going on and they said it’s because i used an aftermarket sensor. Is this true? Or could it be something else?
Old Nov 15, 2020 | 05:21 PM
Answer's Avatar
Answer
Most aftermarket sensors will in fact not register the pressures in the dash...
Old Nov 16, 2020 | 03:51 AM
Napalvr's Avatar
Napalvr
I have ITM sensors in my summer wheels and they do register,but only occasionally which I think is weird
Old Nov 16, 2020 | 05:18 AM
Sasnuke's Avatar
Sasnuke
Welcome to the forum!
As mentioned above, because it is an aftermarket sensor it may not register the pressure on the dash, which in turns blanks out all the pressures.
If you want to see the pressure readings your guaranteed fix is an OEM sensor.
FYI...the sensors are made by Pacific Industries with the code PMV C010 on them...you could even look for a used one on eBay.
Old Nov 16, 2020 | 10:13 AM
doodlebug's Avatar
doodlebug
When I bought my wheels I bought some aftermarket sensors from a local tire shop. I just program them to the ECU each time I switch my wheels. Isn't this all that needs to be done?
Old Nov 16, 2020 | 10:21 AM
Sasnuke's Avatar
Sasnuke
That is correct, however most of the aftermarket sensors don't display the pressures, or inconsistently display the pressures.
If a tire does go low the warning light will trigger regardless of the sensors installed.
Old Nov 16, 2020 | 11:21 AM
doodlebug's Avatar
doodlebug
Interesting. I'd hate for my pressures not to show.
Old Nov 17, 2020 | 12:29 PM
V00D001's Avatar
V00D001
Yeah - I use aftermarket on my new wheels. When I first start the car the pressures come up as - - (dash dash). In less than a 1/10 mile they'll populate with the pressure. They do fluctuate a little more than the OEM sensors too. I should have used the OEM ones but wanted to have my stock wheels ready in case I needed them.
Old Nov 20, 2020 | 04:14 AM
1slowes250's Avatar
1slowes250
Default Tpms
Look into highline tpms...
Old Nov 20, 2020 | 08:14 AM
V00D001's Avatar
V00D001
Why not get Pacific Industries PMV-C010 ....this is the OEM TPMS Manufacturer? You can usually find a brand new set of 4 for under $200. You won't risk having any problems with them vs an aftermarket manufacturer.
Old Nov 20, 2020 | 11:54 AM
TLeexus's Avatar
TLeexus
Default i always PMS over my TPMS
Hoovey689
Sep 29, 2021 05:46 PM
tucker21
May 19, 2016 05:26 PM
Ne1tHeRe
RC F (2015-present)
Apr 1, 2016 08:00 AM
BieberNutz
Wheels, Tires & Brakes Forum
Jan 1, 2016 01:03 PM
GQis350
Aug 26, 2012 08:35 PM
