Adding an amp to factory sub?
Old Sep 14, 2020 | 10:21 AM
SethP's Avatar
SethP
Default Adding an amp to factory sub?
Hi all,
I have a non-ML audio package and have a mono amp that would work perfectly on a sub.
I know many have replaced the sub too, but would it do a lot of good to simply add this amp between the factory amp and the factory sub?
Just not sure if a dedicated amp could help the factory sub.
Old Sep 14, 2020 | 02:16 PM
MattNXF's Avatar
MattNXF
Buy a audiocontrol LOC. A line output converter, or LOC for short, converts a speaker-level output signal into an RCA preamp-level signal. This lets you connect the radio to the amplifier. in your case, allows for a sub
Old Sep 16, 2020 | 10:26 AM
GR3Y5H3ART's Avatar
GR3Y5H3ART
after finishing my aftermarket Sub install, i haven't even upgraded the Front door speakers because with/Sub, Amp, Cap, Loc upgrade...it sounds much better
if you are looking for more Bass, adding an amp to the non-ML won't help too much if any
if you like crystal clear music but zero bass, upgrading OEM speakers would be your best bet
great thing about non-ML is Lexus made it very easy for aftermarket upgraders to install any/all upgrades
this is my experience:
Install: DIY Non ML Amp - Aftermarket Subwoofers Amp Capacitor
https://www.clublexus.com/forums/is-...capacitor.html
Old Sep 16, 2020 | 07:20 PM
sixbanger's Avatar
sixbanger
The only way I would recommend doing this is if you plan to eventually upgrade the sub.
You won't hurt anything, but I would expect little or no improvement in sound quality or added bass.
SSmith
SC400 / 300 Classifieds
Aug 15, 2013 11:54 AM
DGIKULJOT
May 5, 2013 11:10 AM
bacardi
Feb 15, 2013 06:35 AM
Sheehan1p
Dec 20, 2009 12:49 PM
