headlight is this a seal unit
Old Sep 13, 2020 | 03:58 AM
williex's Avatar
williex
Default headlight is this a seal unit
my headlight stop working on my 2014 is 250 is the headlight a sealed unit or can i buy a module.
and have it installed
Old Sep 13, 2020 | 04:23 PM
tofuprod's Avatar
tofuprod
If they are LED, they are sealed. Chances are you need a whole headlight.
Old Sep 14, 2020 | 03:10 AM
williex's Avatar
williex
Default s headlight a seal unit
The headlight is a projection headlight
Old Sep 14, 2020 | 04:39 AM
Voronmetro's Avatar
Voronmetro
How many lenses does your headlight have? If 1 - HID, if 2 - LED. You can change the control unit in the headlight if you are sure that it was he who broke.I changed the control unit in my headlight on the weekend, if the main beam breaks down, it will turn out to be changed without removing the headlight, if the near one (like mine) needs to remove the bumper
Old Sep 14, 2020 | 09:19 AM
dakest's Avatar
dakest
I am interested in this also, I have the LEDs and they both work but I get the headlight error.
Old Sep 14, 2020 | 05:26 PM
williex's Avatar
williex
Thanks It has 1-HID will get a control where did you buy yours from and whats the price.
Old Sep 14, 2020 | 11:20 PM
Voronmetro's Avatar
Voronmetro
If you have HID, then maybe your lamp just broke and you don't need to buy a control module. It's easy to check, remove the lamp from the working headlight and put it in a non-working one, if the headlight works - just buy a lamp, if not you need a HID control unit. (I have LED headlights, I changed the LED control unit)
Old Sep 15, 2020 | 09:06 AM
dakest's Avatar
dakest
If I may ask, how did you change the led module? you can pm me so we don't use anymore space on this post.
Much appreciated.
Old Sep 15, 2020 | 02:32 PM
athanato's Avatar
athanato
Was LED even an option for 2014?
Old Sep 15, 2020 | 06:19 PM
kj07xk's Avatar
kj07xk
Yes. I have LEDs on my 2014 IS350 AWD.
Old Sep 16, 2020 | 05:29 AM
williex's Avatar
williex
Default headlight not working
Much appreciated.
will do as requested i will contact you later today as i am also getting it looked at
Old Sep 16, 2020 | 01:37 PM
dakest's Avatar
dakest
Thank you so much!
Old Sep 17, 2020 | 04:59 AM
williex's Avatar
williex
Hi guys thanks for th assistance i went to the dealers and it turned out to be a bulb had it replaced.by them ...was a little expensive
Which bring me to the point what COMPANY would be good to order parts from at reasonable prices
Voronmetro Thanks.
2genIS
Sep 7, 2017 09:32 AM
skymonkey2
Feb 26, 2012 06:03 PM
