So I was swapping the battery out with a new one and to make a long story short, I put the battery in the wrong way.
I found lots of info on the 2is forums but the 3is has a different fuse box. Does anyone know how to trouble shoot this?
There is no sign of life.
More specifically is there a way to test the main fuse without having to pull out the entire fuse box to have a look?
Maybe you can PM the member from this thread and see how he made out with the same issue: https://www.clublexus.com/forums/is-...l#post10844372
Realistically fuses have blown, and likely they are part of the fuse block mentioned in the above thread.
Here i am. Oh man that was a headache.... They ended up changing the entire fusible link block. Asking with a bunch of blown fuses all over the car. Then he has to reset a bunch of codes. He also said there might be long term damage to the alternator that we won't see till later down the line 🙃
