what's going to break on my car next??
fellow mouth breathers,
i have a 200t with about 40k miles ..... i know this is bit of a *****y question for a newer toyota, but ,,,, what's going to break on my car first? what's likely going to be my first major maint cost?
excluding brakes
and which service intervals are the most critical ones?
[before you yell at me, i'm also doing research on CL ... but wanted to start dialog here]
excluding brakes
The following 2 users liked this post by davyjordi:
Jazzrock (07-09-20),
MobileMike (07-09-20)
Probably water pump
turbo pressure regulator
LED DRL
brake pads
tires
potential later on: carbon deposits
maintenance like any other car. all oils and fluids and filters.
LED DRL
brake pads
tires
TLeexus (07-09-20)
Received 1,732 Likes
excluding brakes
excluding brakes
First to go will likely be the pressure regulator...TSB to cover that.
Potentially next carbon deposits in the motor...which isn't really anything breaking, just seems to happen on the NX with the same motor...of course I suspect vehicle usage plays a factor.
Maybe the waterpump next...a couple have failed...but really not the end of the world.
Wear and tear items I don't really count...brakes (like you mentioned) and tires...they are designed to wear out, so shouldn't "break" per say
As it's a turbo motor, keep up with engine oil changes diligently.
Other fluids can be replaced as needed...most notably: tranny, diff, and coolant
Spark plugs...definitely want to keep on top of those with regular replacement intervals...as per owners manual if not sooner.
- adding an oil catch can
- Seafoam product for cleaning the intake and valves
- In-tank fuel injector cleaner
- Using Premium fuel diligently
TLeexus (07-09-20)
I had 2IS for 5 yrs and now 3IS for 7 yrs knock on wood nothing major items have broken. The only thing was battery drain issue on 3IS aside from that it's pretty much bullet proof.
I only hope the radio and F-sport gauge will not break next 2-3yrs these items are going out for lots of 2014 owners.
Yeah the LED DRLs are known to fail. And so are the amps for the radio, sometimes the blend door actuators for the AC.
Carbon deposits as I said would require a top end rebuild. Short of changing your oil and filter frequently, not much else you can do to mitigate it. It's up to the design of the powertrain at that point.
There was a post on this forum from a Lexus tech who tore down and photographed two turbo-4 lexus engines which were replaced under warranty for carbon deposits causing misfires. the reality of direct injection. Both engines had around 60k on them.
LEDs - a handful have failed and it appears to be earlier years...OP has a 200t, so either 2016 or 2017
Amps - issue with 2014 models for sure...once again, OP has a 200t, so either 2016 or 2017
Blend doors - there has been a number of cases of this, but mostly earlier models
Carbon deposits as I said would require a top end rebuild - what are you rebuilding exactly? There's are options before you start to pull the cylinder head off...and once again, this is an issue on the NX, not the IS, even though it's the same engine. There may be reasons that this is happening on the NX that are beyond the fact it's the same engine
There was a post on this forum from a Lexus tech who tore down and photographed two turbo-4 lexus engines which were replaced under warranty for carbon deposits causing misfires. the reality of direct injection. Both engines had around 60k on them. - True, and both engines were from an NX if I remember correctly.
Don't worry...its a Lexus. I would do an Italian tune up daily and just enjoy the car. I had my IS350 for 5 years, almost 60K and not a single thing went wrong with it. Sold it to family and they put a ton of miles and still, nothing wrong with it.
Most college students/ young people/ young executives, etc. don't go to enthusiast forums to report problems. There's a Lexus tech on Reddit who says they are seeing quite a few Lexus 4-turbos come in with misfire codes due to clogged valves/valve seats due to carbon deposits. Sort of an insider's look at what's going on. Food for thought.
