Battery Change
Old May 15, 2020 | 11:08 AM
nkseto's Avatar
nkseto
Default Battery Change
Hi All - are there any codes that need to be input into the radio/navi when changing the battery? Would I need to get these codes at the dealer or can I swap this out at home?
Old May 15, 2020 | 11:54 AM
Flash5's Avatar
Flash5
Nope. Just swap it out and you’re good.
Old May 16, 2020 | 01:19 PM
bob123's Avatar
bob123
Engine will probably quickly stop after your first start with the new battery, but it's normal if you didn't hook up a battery charger to the OBD2 port prior to removing the battery.
Once you restart the car again, it will start up as normal without codes.
Old May 16, 2020 | 01:54 PM
Napalvr's Avatar
Napalvr
Whats a good brand to go with. I’m on 5 years now and should replace mine this summer
Old May 16, 2020 | 02:08 PM
Flash5's Avatar
Flash5
You’ll find a lot of batteries are manufactured by the same core company or companies with different labels on them. Interstate, ACDelco, and Optima are good ones. The Lexus OEM batteries are solid too tbh. I haven’t really done much research on who makes whose batteries.
krawfo
Mar 7, 2024 05:20 AM
waterchng
Oct 8, 2019 05:55 PM
777rx400h
Hybrid Technology
Mar 20, 2019 09:11 AM
jbone29
Aug 24, 2012 07:15 AM
