2015 IS 250 Fsport, rotor replacement.
Old May 13, 2020 | 07:28 PM
BurberryBV's Avatar
BurberryBV
Default 2015 IS 250 Fsport, rotor replacement.
I need to replace front and rear rotors, which ones to you Guys recommend. I’ve been having issues finding aftermarket ones online for my specific model. also leaning away from slotted/drilled. Just put akembono pro act ceramics for front/rear pads.
Old May 13, 2020 | 07:37 PM
BurberryBV's Avatar
BurberryBV
Default Oem
Worst case scenario I can get OEM rotors
Old May 13, 2020 | 08:18 PM
Miintt's Avatar
Miintt
Check out R1 Concepts. They make oem like rotors as well as drilled/slotted for our cars and they are a forum sponsor. I’ve heard great things about their products. I bought their slotted rotors for my car but haven’t had a chance to install yet.
Old May 13, 2020 | 10:14 PM
m0chafrap's Avatar
m0chafrap
Running Akebono ProACT w/ Centric high carbon rotors (OEM style blanks). Having a great experience - about 1 year and 17k miles in and the pads look at least 80% new still, no lips forming on the rotors and best of all... way less brake dust and squeal. Small penalty with initial bite, especially if the pads are cold, but they work just fine after getting heat in them. 10/10 would recommend.
Old May 14, 2020 | 12:45 AM
wongnee's Avatar
wongnee
Get the original ADVICS disc?
43512-30310 (front)
Old May 14, 2020 | 12:50 AM
wongnee's Avatar
wongnee
Don't know the size of your wheels, if they're 18" I would recommend getting a set of new GS350F front brake,
they are lighter, larger, better.
Old May 14, 2020 | 06:01 AM
HAYSTACK's Avatar
HAYSTACK
How about Centric? I haven't ran these on my Lexus, but I run them on my daily. I run stop tech slotted in front and Centric in the rear.
https://www.autoanything.com/brakes/61A5250A0A0.aspx
Old May 14, 2020 | 07:36 AM
tofuprod's Avatar
tofuprod
This is probably the best bang for buck. The lady has this setup on her '15 250 F sport (AWD) and zero issues.
Old May 14, 2020 | 07:39 AM
BurberryBV's Avatar
BurberryBV
I’ll def Check them out thanks bro
Old May 14, 2020 | 07:43 AM
BurberryBV's Avatar
BurberryBV
centric and stop tech were some popular ones I’ve been seeing, ill keep the centric high carbons in mind!
Old May 14, 2020 | 08:32 AM
BurberryBV's Avatar
BurberryBV
I got the part numbers for OEM rotors from my Lexus dealer.
front: 43512-30310
rear: 42531-30300
wanna double check and make sure these are correct And best OEM for my fsport
Old May 14, 2020 | 08:42 AM
evltwn's Avatar
evltwn
front: 43512-30310
rear: 42531-30300
Looks like those are for the Non-FSport.
https://www.mylparts.com/v-2015-lexu...--front-brakes
Scrool down and you'll see the difference in the 2nd part of the part number.
Old May 14, 2020 | 10:08 AM
HOMER350's Avatar
HOMER350
Would need a whole new setup for that, new calipers. Easy enough sounds like after that but can't only replace the rotors.
Old May 14, 2020 | 09:40 PM
wongnee's Avatar
wongnee
front: 43512-30310
rear: 42531-30300
The P/N for front should be correct, but please upload pictures of your current discs.
One look, we can tell:
https://jp-carparts.com/lexus/part_d...3&part=1271835
P/N for rear... should be 42431-30300:
https://jp-carparts.com/lexus/part_d...2&part=1271581
Old May 15, 2020 | 02:54 AM
LaZeR's Avatar
LaZeR
How & Why is going OEM a "worst case scenario"? lol When it comes to brakes, pads, rotors, etc, IMO always prefer to go OEM, or at minimum Lexus recommended, but for lotsa other stuff don't care too much going after market parts. Anyway, once again, just a 2 cents opinion & preference.
bripcon
Feb 12, 2020 08:09 AM
TheWizard
Oct 20, 2019 05:34 PM
Silec
Feb 24, 2018 09:45 AM
gekae24
Feb 22, 2017 02:06 AM
is250smoke
Jun 3, 2016 08:36 AM
