Replacing factory 8" subwoofer
Old Apr 25, 2020 | 09:10 PM
rk350's Avatar
rk350
Default Replacing factory 8" subwoofer
Has anyone upgraded the factory 8" sub? I don't have the ML system, and was thinking of swapping out the sub for a better one, wondering if its easy enough to do and did it sound better?
Thanks
Old Apr 26, 2020 | 08:03 AM
flexspace's Avatar
flexspace
I just did it, actually. It sucks taking your rear seating area apart, but that's how you access the sub. It should be noted that Lexus does not make it easy to replace factory audio components.
The sub has its own bracket that it is highly integrated into itself. Other members opted to just drop the new sub straight in with U-clips, but I chose to "extract" the bracket from the factory sub and use it with the new one. It does make a difference, the stock sub weighs less than a sandwich.
I will post a write-up when I get time.
Old Apr 26, 2020 | 04:04 PM
TonyN's Avatar
TonyN
specs on the replacement sub and if it sounds good with factory amp. I'm non ML and just want a bit more bass
Old Apr 27, 2020 | 09:59 AM
flexspace's Avatar
flexspace
Any shallow mount subwoofer in 8" should work.
https://www.crutchfield.com/ISEO-rgb...FC-XW800F.html
This is the one I have; I do encourage to think about how you're going to mount it since it's not a flat surface on the rear deck.
Old Nov 16, 2020 | 11:25 AM
colabro's Avatar
colabro
I hate to bring up a dead thread but I figure it's better than starting a new thread with every question I have.
The subwoofer you linked above, did it just drop into the OEM enclosure, or did you have to go another route? I'm really hoping to use the OEM enclosure rather than build an enclosure or baffle. Also, looking at the power requirements, did this sub require an aftermarket amp or will the factory amp be acceptable? 50-150 watts isn't too terribly much. I fully understand the sound quality will not be up to par with a good aftermarket amp.
Added: Edmunds reports the 8-speaker audio system as having 293 total watts. Anyone know how much of that is sent to the subwoofer?
Last edited by colabro; Nov 16, 2020 at 11:47 AM. Reason: Added info and question.
Old Nov 20, 2020 | 09:29 AM
Lee350F's Avatar
Lee350F
I'd check out SixBanger's budget build for non-ML. It's a pretty good write up https://www.clublexus.com/forums/bui...reo-build.html
peter007
Aug 10, 2007 12:43 PM
The Ikon
Jan 28, 2002 09:14 PM
