Steering Wheel control panel
If you flip that connector around, is there an empty cavity that you can put the Ground wire in?...if you need.
If the Ground wire is not there, then the connector should have an empty cavity. Swapping the one wire over isn't hard if you have some small tools.
Aside from white/black stripe Ground wires, Toyota also uses Brown wires as Grounds...which I see one Brown wire in that connector.
lexusfan05
Jul 12, 2019 12:04 PM
funcrusher
Feb 20, 2019 09:24 AM
Aleks1
CT 200h Model (2011-2017)
Oct 20, 2015 10:52 AM
