Custom drl power source
Old Oct 11, 2019 | 04:52 PM
Ghanberg's Avatar
Ghanberg
Default Custom drl power source
I recently installed the profile pixel DRL boards and to get power for the Bluetooth I piggybacked from the washer fuse, therefore when the ignition is on they are always on. My question is if anybody knows how I could hook up to the DRL switch so they only turn on when they're supposed to?? If there's already info on this I'm sorry I just signed up today this is the first time I've posted 🤷 thx in advance
Old Oct 14, 2019 | 11:40 AM
Sasnuke's Avatar
Sasnuke
By DRL switch, do you mean the stalk switch on the steering column that has the DRL Off option? If you have that model switch.
I think many reading this may not understand the question exactly, so hard to give an answer.
Old Oct 14, 2019 | 12:33 PM
Pittsy's Avatar
Pittsy
Yes, behind the bumper where the stock DRL Harness plugs in (That you dont use anymore) Is where you tap it. Should retain the stalk functionailty, Thats where I had mine tapped on my IS when I did the exact same kit as you.
Old Oct 14, 2019 | 01:21 PM
Ghanberg's Avatar
Ghanberg
Yeah I kind of figured I could do that but I was trying to avoid removing my bumper again, by accessing the power source through the engine bay. But I'll be removing the bumper next month anyways to do my grill & emblem and I'll Tinker with it then thank you very much for the info.
G
IntrinoX
Sep 10, 2019 04:40 PM
TeaAholic1
NX - 1st Gen (2015-2021)
Feb 5, 2016 06:36 PM
homoonar
HS 250h Model (2010-2012)
Jun 30, 2014 04:56 PM
CAK 500
May 13, 2010 06:05 PM
Dj_AmtraX
May 24, 2007 02:47 PM
