Aftermarket heated seats (not what you think)
Question for any Lexus techs on this forum (or anyone else knowledgable about the 3IS). I've seen the thread about the weak heated seats in the IS. I am planning on installing an aftermarket head unit in the glovebox and extending the faceplate to where the heated seat controls are, which will require re-locating the heated seat controls. Unfortunately, there is a huge board underneath the controls so I can't re-locate the factory controls since there is no spot big enough to integrate them in the center console. I'm not happy with the weak heated seats anyways and thinking of just replacing them with aftermarket heated seats and locating the switches in the center console between the cupholders and nav pad. Does anyone know if the factory heated seat elements are sewn/glued to the seat cover? And if so, would there be any issues just disconnecting the factory heated seats and installing the aftermarket elements between the cushion and seat cover (underneath the factory elements)?
Thanks!!
Thanks!!
Received 1,738 Likes
I haven't looked at the threads for the seat heater as I don't usually use mine, so I have no complaints about it.
I'm sure the thread mentions the TSB to replace the front seat heaters and A/C amplifier to fix the poor heat condition.
To answer your question, the F Sport seat has the heater attached to the cushion.
The non-F Sport seat has the heater attached to the cover.
If you're going to toss the factory ones, then I would just try to seperate it from whatever it's attached to. It's not like you're reusing them.
Installing it on top the cushion if the OEM heater is attached to the cushion shouldn't be an issue.
But if the heater is attached to the cover, then it might inadvertently provide an extra layer of insulation that you may not necessarily want.
clov3r (04-01-19)
For reference I've attached the TSB. It appears it only relates to F Sport IS's.
clov3r (04-02-19)
