Installed RCF / GSF bushings..
Old Mar 22, 2019 | 08:37 AM
swaangin's Avatar
swaangin
Default Installed RCF / GSF bushings..
i posted a tire wear thread and everyone recommended getting upgraded bushings, I decided to get with the Lexus bushings (RCF) ones from hollywood Toyota aka discount monster.. had them installed today but I do not feel a difference.. car feels more stable at higher speeds 70mph+ but besides that I’m not sure what I should look for. I asked the mechanic if he noticed a difference between my stock bushings (2015 IS 250) vs the new bushings and he said no but he felt that the rubber was more stiff.. I think he thought I was doing this for no reason lol.
Can you guys tell me what differences I should look for?
Old Mar 22, 2019 | 08:43 AM
JNP1227's Avatar
JNP1227
Brake hard and see if the car feels more stable. I know with my RR bushings it has greatly reduced the nose dive.
Also, the steering should feel more precise with improved feedback.
Old Mar 22, 2019 | 08:49 AM
TonyN's Avatar
TonyN
thats exactly what should happen, the bushing is a little stiffer, not urethane stiff. It will improve stability on the highway and will reduce the wandering, it will reduce the dynamic toe on acceleration and deceleration, this is what reduces the toe wear you noticed. If you want to completely get rid of the wear go urethane but you will feel bumps and road conditions in your steering wheel and it will squeak if not lubed up.
i have had the bushing on the front for 6k miles and no indication of wear as before.
Old Mar 22, 2019 | 08:50 AM
NickCaesar's Avatar
NickCaesar
steering wheel should be a bit firmer and move less especially under hard braking and acceleration. You should also notice the car doesn’t pull to a certain side on roads with a slight angle. My car use to pull left and right a lot almost like it needed an alignment, after the bushings install all those things are gone. Should be quite noticeable.
Old Mar 22, 2019 | 12:14 PM
swaangin's Avatar
swaangin
Yeah, just drove it after reading the comments, breaking hard, car goes straight, doesn't move.. steering feels a little bit more planted, close to stock. High speed driving is a lot more stable, I was expecting a bit more but it's fine.. But, another question, why do the bushings look identical to the stock ones? They literally look the same.
Old Mar 22, 2019 | 12:27 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
They're of the same design to the originals, they're essentially just stiffer rubber.
Jeff
Old Mar 22, 2019 | 02:44 PM
sunamer's Avatar
sunamer
The difference is not in the geometry of the bushings, but rather in stiffer material of the bushing. That will lead to less flex created by a lower control arm, and as a results less toe out during hard braking and cornering.
Old Mar 22, 2019 | 11:40 PM
swaangin's Avatar
swaangin
Yeah, mechanic told me the rubber was stiffer than original but he thought it might be because they are "new" and will wear off, I guess its doing the job.
Old Mar 23, 2019 | 02:42 AM
Flash5's Avatar
Flash5
Definitely not because they are newer haha. I mean I’m sure new OEM IS bushings will be a little stiffer than really old ones, but the GS-F/RC-F bushings are definitely stiffer than new IS bushings.
Old Mar 23, 2019 | 10:35 AM
sunamer's Avatar
sunamer
I kinda doubt that. AFAIK older bushings become more brittle and tear into pieces, unless petroleum products were leaking on them during their life, which would make them softer...
Old Mar 23, 2019 | 04:45 PM
Ak0ng's Avatar
Ak0ng
I have a 2014 rwd gs350 f sport and I just installed my sets of gsf/rcf bushings today. The feeling through corners now is exactly what you described it to be.
I found that the stock bushings on my car had a larger ​​​rubber diameter and softer compund than the gsf/rcf bushings
Old May 15, 2019 | 09:41 AM
aniks's Avatar
aniks
Just out of curiosity, where does one get these installed? I would love to do it myself. But i don't have the tools, nor do I have a driveway or garage. Would a tire shop do this? Or some sort of suspension/brake shop be advisable? The only lexus mechanics in my area are the dealer and a place called integrity auto.
Old May 15, 2019 | 09:45 AM
Ak0ng's Avatar
Ak0ng
A simple mechanic shop should be able to do the job.
Old May 15, 2019 | 09:58 AM
NickCaesar's Avatar
NickCaesar
It is a 30 min job from start to finish. Do not pay more than 1 hour labor to have it done regardless of where you go.
Old May 15, 2019 | 11:14 AM
VisualEcho's Avatar
VisualEcho
A few questions for myself, and those that might find this thread in the future.
1. Can you post the part number, quantity, and maybe a link to where you bought them?
2. Does installation require an alignment?
3. Are there any stock alignment settings that can be adjusted to help the tire wear as well? Or should the stock alignment settings be used?
