2014 is250 fuse problem???
Old Mar 16, 2019 | 11:31 PM
Peteypete's Avatar
Peteypete
Default 2014 is250 fuse problem???
Recently, my radio/navigation screen went out and im guessing its a bad fuse. Which fuses should I check? I already checked all the fuses under the hood, & checked 15a radio on the drivers side. Is there any other fuses that may affect radio/navigation screen?
Old Mar 17, 2019 | 07:44 AM
Sasnuke's Avatar
Sasnuke
Chances are it's likely the radio head unit that has crapped out.
If you've checked the fuses under the hood and they're ok, might as well check all the ones in the drivers kick panel to be sure.
I can't remember all the ones related to the audio system, but it's only a couple.
If the Radio fuse is ok, then the radio should at least turn on and respond.
Unfortunately 2014 head units crapping out isn't uncommon.
Old Mar 17, 2019 | 01:57 PM
JNP1227's Avatar
JNP1227
Like Sasnuke said, you will probably need a new radio unit.
I had mine replaced a few months ago bc my navigation screen went black and now I am getting it replaced again due to the USB port not working.
Old Mar 17, 2019 | 02:23 PM
NickCaesar's Avatar
NickCaesar
if one of the 2 USB ports break the whole nav unit has to get replaced??
Old Mar 18, 2019 | 06:52 AM
JNP1227's Avatar
JNP1227
Not exactly, they replaced the USB port part but that didn't resolve the issue. Then they checked the make sure the pins were attached correctly behind the dash and they were. So they said they will just replace the radio unit as its covered under warranty.
wrc
Aug 15, 2022 01:00 PM
joeyfett
Sep 3, 2013 11:25 PM
questnyc
Apr 22, 2008 05:19 AM
BkLexZ
Oct 6, 2006 09:33 PM
tbridgers
Maintenance
Feb 19, 2005 02:37 PM
