Missing part above transmission display
Old Mar 3, 2019 | 05:03 PM
stevenlamx's Avatar
stevenlamx
Default Missing part above transmission display
Hello!
I have a 2016 Lexus IS 200t and I am missing a piece right above the transmission. Can someone tell me what the technical term for that piece is or possibly the link to where I can order it? Thank you! Also anyone know if the transmission display can be replaced? Mine is a bit scratched up
Old Mar 3, 2019 | 05:58 PM
arentz07's Avatar
arentz07
Hey, we just had the exact same question recently. See the following thread:
https://www.clublexus.com/forums/is-...hift-****.html
You can use the "Search this forum" button as circled in red in the below screenshot.
To answer your question, that part is the shift-lock release. If used, it will allow shifting out of park while the vehicle is turned off.
As for replacing the shift display, I haven't had any luck finding the part. Probably best to work with a dealer or shop who would have access to that information.
Old Mar 3, 2019 | 07:30 PM
stevenlamx's Avatar
stevenlamx
Thanks for that!
I seem to have found this part #3355450040. Do you think this will fit?
Old Mar 3, 2019 | 07:41 PM
arentz07's Avatar
arentz07
Hey Steve, that part appears to be for an LS430.
I did manage, after further digging, to find this: https://parts.lexus.com/a/Lexus_2016...2430-5806.html
I think what you want is in there, though I am having a hard time discerning which part it is - might be under 58808*, but not sure.
Old Mar 5, 2019 | 03:11 PM
E46CT's Avatar
E46CT
Extremely hard to find. This is from a new tacoma which I wouldn't doubt shares parts with Lexus. It looks close... maybe i'll look at mine later to see if it matches this.
https://www.ebay.com/itm/NEW-TOYOTA-...ss!92620!US!-1
Old Mar 6, 2019 | 10:04 AM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
33554-24070 - Shift Lock Cover
35978-53151 - Shift Indicator (includes Shift Lock Cover)
The cover can be bought at a dealer for couple of dollars, if you want to buy it online you can find it for less than $1. The indicator is unfortunately quite a bit more expensive.
Jeff
itsmeegan
RX - 1st Gen (1999-2003)
Mar 24, 2010 02:32 PM
turbodremz
Mar 10, 2010 08:27 PM
GarrettSC
Jan 27, 2007 04:49 PM
Bongos
Oct 8, 2006 07:14 PM
