Wheel Spacers - Final Analysis
Old Feb 16, 2019 | 10:59 AM
  #31
darkfire's Avatar
darkfire
Originally Posted by Flash5
I’m about to try the ones E46CT recommended and uses. They are a random brand on Amazon but they are priced right and he hasn’t had issues. They are hubcentric and everything.
Thanks Flash, would you mind linking? Would love to wish list them if nothing else!
Chris
Old Feb 16, 2019 | 12:29 PM
  #32
Flash5's Avatar
Flash5
Chris
Customadeonly 2 Pieces 0.787" 20mm Hub Centric Wheel Spacers Bolt Pattern 5x114.3 Center Bore 60.1mm 12x1.5 Stud 25/32" Fits Toyota
Amazon Amazon
Old Feb 17, 2019 | 02:09 PM
  #33
HOMER350's Avatar
HOMER350
Originally Posted by swaangin
Can you post new pics?
Customadeonly 2 Pieces 0.787" 20mm Hub Centric Wheel Spacers Bolt Pattern 5x114.3 Center Bore 60.1mm 12x1.5 Stud 25/32" Fits Toyota https://www.amazon.com/dp/B00II7R5N2..._0jhACb25RQX6N
yup, those are the ones I'm using. Multiple members here said they had installed for long enough with no issues. I have the black ones, 20mm front and 15mm rear.
Heres a couple new images as requested.
Not exactly the same appeal but I like it, still looks much better.
15mm after
20mm before
Old Feb 17, 2019 | 03:37 PM
  #34
Flash5's Avatar
Flash5
15mm after
20mm before
Any reason you went with black instead of the regular shiny silver?
Old Feb 17, 2019 | 04:40 PM
  #35
HOMER350's Avatar
HOMER350
The others looked a little too polished and stood out too much. I guess also to keep consistent with black calipers I have and rotors/wheels to come.
Old Feb 17, 2019 | 07:06 PM
  #36
swaangin's Avatar
swaangin
15mm after
20mm before
I think the 15mm looks better, the 20mm makes the wheel kind of angle out, thanks for the pics man, I will probably go for the same set up with RSR down springs on my non F sport.
Old Feb 17, 2019 | 07:45 PM
  #37
truu's Avatar
truu
25/20 mm spacers on stock suspension. I have lowering springs on the way which will drop it 1.4/1.0 inches. BTW, I do rub with stock suspension.
Old Feb 18, 2019 | 08:48 AM
  #38
TonyN's Avatar
TonyN
20mm all the way around, stock suspension and stock tire size. No rubs with 4 adults in the car, factory alightlent specs with GSF front lower control arm bushing.
Old Feb 18, 2019 | 09:43 PM
  #39
AtomicAWD's Avatar
AtomicAWD
Yup, looks good, HOMER, and for the miniscule difference the basically guaranteed no-rubbing is worth it imo. Speaking of "angled-out", it looks like all our cars have noticeable camber in the rear? Mine stock sure looks like it.
Old Feb 24, 2019 | 10:31 AM
  #40
igetit14is's Avatar
igetit14is
Just rear. And not all that hard to do either it was obvious within minutes of driving.
Not constant either but I will be replacing with 15mm for rear.
Thinking maybe tire brand has to do with why there is inconsistency with people rubbing.
I have Goodyear EagleSport all season.
I've read there are some variances in shape and sidewall structure across brands but I don't know if that would make the difference.
You're absolutely correct about the variances in tire size, Goodyear has a very wide footprint with a square shoulder where as Continental or Bridgestone is more rounded.
Old Feb 24, 2019 | 02:23 PM
  #41
HOMER350's Avatar
HOMER350
Thanks for helping to confirm. It looks like it in the images but not exactly something mfg. will or should specify.
Old Mar 23, 2019 | 01:59 PM
  #42
swaangin's Avatar
swaangin
@HOMER350 How does the car drive with the spacers & drop? Also, link to spacers used? Thanks for the info btw
Todd Edge
Apr 24, 2026 09:05 PM
Fischy13
IS F (2008-2014)
22
Mar 9, 2016 04:05 PM
RSXiMUS
IS F (2008-2014)
Jan 29, 2015 09:16 AM
tmoney16
Sep 24, 2014 04:47 PM
krue92
IS F (2008-2014)
Sep 12, 2011 06:06 AM
