Bc coils ride quality?
There are plenty of high quality options for coil-overs: https://www.topendmotorsports.com/le...on/coil-overs/
You can get TEIN Flex Z for under $1000: Flex Z Damper Coil-Overs
im guessing I can find me a whole set of these shocks and get rsr half downs springs? https://www.ebay.com/itm/LEXUS-06-16...LIHa:rk:5:pf:1
The half downs will also even out the front/rear wheel gap.
Check out this thread:
https://www.clublexus.com/forums/sus...f-downs-3.html
Tim151 also used half-downs on his build, lots of good pictures of what it looks like drop wise:
https://www.clublexus.com/forums/bui...-thread-4.html
Contact us for pricing!
-Josh
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
You should search the threads for pictures on different springs.
When I was researching I saw that half downs didn't lower enough if at all.
I went with the down springs which I think is perfect.
Super downs were too dumped for me.
Just something to keep in mind before pulling the trigger.
Good luck!
Good luck!
