Need hubcentric rings for new wheels
Old Dec 17, 2018 | 01:46 PM
tekmode's Avatar
tekmode
Default Need hubcentric rings for new wheels
Ordered a set of Work wheels, but not sure which size hubcentric rings I need to order
i know lexus bore size is 60.1
Old Dec 17, 2018 | 01:59 PM
TonyN's Avatar
TonyN
find out the bore size of your work wheels and there you go
Old Dec 17, 2018 | 02:33 PM
E46CT's Avatar
E46CT
If you are careful in the correct torque sequence during install, you don't technically need rings. They're really for convenience more than anything.
If you want to ensure speedy install or if others work on your car, then the rings can make sure even torque is applied.
TL;dr, it's better to have them, but not completely necessary.
It's even best/better to have proper wheels that are actually made for your hub.
Old Dec 18, 2018 | 01:13 PM
Sasnuke's Avatar
Sasnuke
It really depends what the manufacturer cut the bore at for the wheel.
Typically for something that will fit our car they will bore the rim to 73.1...so you would need a 73.1 to 60.1 hubcentric ring adapter.
Despite what others may think, you're better off having the ring there...it will aide greatly in centering the wheel before you torque it down.
I could say that technically you only need 4 nuts to hold the wheel on instead of 5, but what would be the point...put all 5 nuts on....just like, put the adapter ring on.
And yeah, in a perfect world the bore of the rim would match the hub on the vehicle, of course this would drive the cost of rims up as they would have to be made on demand...and we're not outfitting Ferrari's here, just a Lexus IS.
Might as well ask for the nut holes to be cut like the OEM rims so we can use the same nuts...dare to dream!
bucanero
Dec 18, 2013 11:00 AM
is250diva9
IS - 1st Gen (2001-2005)
Aug 19, 2012 11:39 PM
PHML
Wheels, Tires & Brakes Forum
Jul 10, 2008 08:09 PM
garethr
Jul 9, 2007 06:48 AM
